300hp 1800lbs is the goal
What is this tube at rear of car?
I didn't find anything with the search (maybe I'm not looking for correct name)
What are these 2 tubes (one on each side of rear) ... I'm guessing that they were for loading cars onto a cargo ship in the early days with a crane. ![]() Next question... if that is infact what they are for (when paired with the multiple steel loops in front trunk) I'm assuming that as long as they are not corroded, I should be able to use them to lift the rear of the car? tks, Evan
The '66 912 Bastardization project has begun. Note to PO's: LAY OFF THE FREAKING BONDO!!!! The science was settled: Earth was flat. Galileo : Flat Earth denier.
Tube is a fender support; it is NOT robust enough to use to lift the car. Nor is it strong enough to be used as a car tie down.
okay... I guess I'll toss that idea in bin...... aswell as those tubes since car has FG flares :P
+1 on the support bracket.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
You'll want to replace them with some sort of support to the fiberglass. Otherwise the fiberglass will shudder in the wind and eventually crack. ( I could show you pics, but I try to delete all the bad ones.)
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
. Looks shaped differently than mine ...
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
Dog-faced pony soldier
Looks like a very efficient tire-puncturing device.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Yup, it looks like it has been bent inward and upward.
Funny, I asked this same question 4 years ago. When i got my '71, it had an impact bumper on the back. That lasted a day.
