RKC RKC is offline
Sway Bar end should be smooth, right?
Replaced my squeaky sway bar bushings and there is no squeak now but noticed the passenger side (which was were the squeak was coming from) was rough on the last few inches. It looked like a blister or a sunburn - some sort of rust-type roughness but metal colored. Will this lead to a new squeak? Do I need to replace the bar? Shouldn't it be smooth like the other three mounting points?
Didn't see indications of metal touching metal, and the old bushing wasn't torn through (though it was pretty beat up). Can it be ground smooth or do I just need a new one?
Old 04-21-2008, 07:53 AM
Evil Genius
Rusty Heap's Avatar
Yup, metal should be smooth, maybe the paint scuffed a bit, I'd at minimum scotch brite the heck out of it with brillo pad or sand paper, repaint and heavily grease that side. I just replaced all my bushings and had little or no wear even on my swaybar paint. No squeeks either.
Life is a big ocean to swim in.
Wag more, bark less.
Old 04-21-2008, 08:25 AM
Somatic Negative Optimist
Gunter's Avatar
Depending on how deep the rust/roughness goes, and depending how tight the new bushing is, you can grind/polish the end.
If it's too deep, try filling the groves with JB-weld and smooth/sand it after.
If left untreated, the rough end will grind the new bushing again.
Some squeeking can come from the A-arm rubber bushings.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 04-21-2008, 08:26 AM
