dshepp806's Avatar
Whatzup with this Staveley report?
I recently changed my oil (again). I always sample and send to Staveley's. Some of you may remember my endeavors with Blackstone, attempting to establish a consistent baseline on virgin samples....it didn't happen,...so,...off to Staveley's (since).
I can't seem to find my first virgin analysis of 20W50 Brad Penn,..but DO have my 2nd pass results of the SAME virgin sampled bottle,...as follows:
Iron 2
Chromium 0
Lead 0
Copper 0
Tin 0
Aluminum 1
Nickel 0
Silver 0
Silicon 7
Boron 4
Sodium 593
Magnesium 650
Calcium 2090
Barium 0
Phosphorus 954
Zinc 1131
Molydenum 8
Titanium 0
Vanadium 0
Potassium 0
ViS @ 40 cSt 151.3
ViS @ 100 C cSt 18.98
Water 0
Soot solids & coolants N/A
TBN 8.8
Recent sample during oil change with about 2800 miles on the oil. Do understand that I had been running RP MC 20W50 when I did the BP changeover (my previous oil change)...NOW, it's change #2 with the BP (again). Also,..I forgot that I had run a bottle of Techron through on a FULL tank,...early on, shortly after my previous change.....ANYWAZE,..here's the Staveley report on my LAST (BP #2) oil changeout:
Iron 12
Chromium 0
Lead 5
Copper 6
Tin 0
Aluminum 4
Nickel 0
Silver 0
Silicon 7
Boron 5
Sodium 393 (NOTED AS HIGH, BY STAVELEY"S)
Magnesium 390
Calcium 1969
Barium 0
Phosphorus 1837
Zinc 1203
Molydenum 101
Titanium 0
Vanadium 0
Potassium 0
ViS @ 40 cSt N/A (WHY IS THIS?)
ViS @ 100 C cSt 16.45
Water 0
Soot/solids N/A
Coolants YES, (WTF IS THIS?)
TAN 1.4 (TES, THAT"S RIGHT FOLKS,..."TAN" (not TBN) NO IDEA WHAT THIS IS??>>>
Charles N? Where are you?
Lotsa question here,..where was the MOLY created? Whatzup with Staveley's flag of Sodium level? ("Appears to be high", as their report noted...rec: "checking for source of contamination/monitor")
Time to call Staveley about their reports's listing of a "TAN"...Charles? Is this a separate measurement? Never heard of a TAN.. A typo? If so,..no way the TBN would drop that much, right?
...Just wanted to drill down on this,..see if anyone else out there had experienced the same thing...
Comments most welcomed.
Best,
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-20-2008, 07:57 PM
