Whatzup with this Staveley report?
I recently changed my oil (again). I always sample and send to Staveley's. Some of you may remember my endeavors with Blackstone, attempting to establish a consistent baseline on virgin samples....it didn't happen,...so,...off to Staveley's (since).
I can't seem to find my first virgin analysis of 20W50 Brad Penn,..but DO have my 2nd pass results of the SAME virgin sampled bottle,...as follows: Iron 2 Chromium 0 Lead 0 Copper 0 Tin 0 Aluminum 1 Nickel 0 Silver 0 Silicon 7 Boron 4 Sodium 593 Magnesium 650 Calcium 2090 Barium 0 Phosphorus 954 Zinc 1131 Molydenum 8 Titanium 0 Vanadium 0 Potassium 0 ViS @ 40 cSt 151.3 ViS @ 100 C cSt 18.98 Water 0 Soot solids & coolants N/A TBN 8.8 Recent sample during oil change with about 2800 miles on the oil. Do understand that I had been running RP MC 20W50 when I did the BP changeover (my previous oil change)...NOW, it's change #2 with the BP (again). Also,..I forgot that I had run a bottle of Techron through on a FULL tank,...early on, shortly after my previous change.....ANYWAZE,..here's the Staveley report on my LAST (BP #2) oil changeout: Iron 12 Chromium 0 Lead 5 Copper 6 Tin 0 Aluminum 4 Nickel 0 Silver 0 Silicon 7 Boron 5 Sodium 393 (NOTED AS HIGH, BY STAVELEY"S) Magnesium 390 Calcium 1969 Barium 0 Phosphorus 1837 Zinc 1203 Molydenum 101 Titanium 0 Vanadium 0 Potassium 0 ViS @ 40 cSt N/A (WHY IS THIS?) ViS @ 100 C cSt 16.45 Water 0 Soot/solids N/A Coolants YES, (WTF IS THIS?) TAN 1.4 (TES, THAT"S RIGHT FOLKS,..."TAN" (not TBN) NO IDEA WHAT THIS IS??>>> Charles N? Where are you? Lotsa question here,..where was the MOLY created? Whatzup with Staveley's flag of Sodium level? ("Appears to be high", as their report noted...rec: "checking for source of contamination/monitor") Time to call Staveley about their reports's listing of a "TAN"...Charles? Is this a separate measurement? Never heard of a TAN.. A typo? If so,..no way the TBN would drop that much, right? ...Just wanted to drill down on this,..see if anyone else out there had experienced the same thing... Comments most welcomed. Best,
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia Last edited by dshepp806; 04-21-2008 at 01:42 PM.. |
