-   -   Alum cross member /sway bar ?? HELP (http://forums.pelicanparts.com/porsche-911-technical-forum/405213-alum-cross-member-sway-bar-help.html)
afterburn 549 04-21-2008 05:15 PM
Installing a Aluminum cross member (front) , the old steel one used tabs for part of sway bar mount.
Which or what sway bar now ?? HELP
don gilbert 04-21-2008 06:44 PM
just did the same thing to my 75s. u use the same s/bar . what i did at first was cut off the old mounts on the steel x member and modify them (drilled holes and put a s/bend in them) but then i bought an 82 sc parts car and got the original mounts. it works the same way, its just that the steel x/member has the mounts welded on and the aluminum ones are bolted on. if you want e/mail me and i will ship you my modified ones.
afterburn 549 04-21-2008 06:48 PM
Hmm yea and yes and , no,,? I am thinking now maybe might be a good time to up grade. Now that I have 20 /20 hind sight........ LOL
One of the through body designs might be the right thing to do ??
cfc 04-21-2008 07:49 PM
sway bar
I must be loosing it. If you are installing a front aluminum cross member that must mean you have a 1964 to 1973 car, since they had steel cross members. The sway bar on those cars did not touch the cross member? What am I missing?
afterburn 549 04-21-2008 07:58 PM
No it is a 75, But it had a steel one there and I just want the lighter fare........
