CMXI's Avatar
Wrong Brakehoses?
Is this the correct brakehose for a 84-carrera???
The right connector doesnt seem to match the one on the old line.
Connectors on the car!
Best Regards
Patrick Hansson
Track day car: 911 3.2 915 Black 1984
Daily driver: 911 3.2 G50 Blue metallic 1987
Winter car: Volvo XC90 2003
Old 04-21-2008, 04:42 AM
Nine9six's Avatar
Patrick,
What are you basing your doubt upon? Although looks can be deceiving, they "look" correct to me. Have you pulled the old lines out yet, or are you basing your question on how things appear?
In the top photo, the right side of the new hose should connect to the upper most connector in the lower photo. Break free the top connector and attache the new hose to allow brake fluid to fill the hose, and then plug.
Break the lower portion free and connect the free end of the new hose. This should reduce the amount of air you introduc into your system.
Repeat, and bleed brakes.
HTH...
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 04-21-2008, 02:15 PM
CMXI's Avatar
Originally Posted by Nine9six View Post
Patrick,
HTH...
Perhaps they are correct after all.
The reason i asked is because i dont want to dismantle the brakes and then find that the new hoses doesn´t fit.
This is my first brakejob on a 911.
I am to lay an order of some parts form a dealer here in sweden, and if they were incorrect i would have exchanged them at the same time.. But it seems like i have the correct hoses after all.!!!
//Patrick
Old 04-21-2008, 11:22 PM
To reduce fluid loss from the system, depress and hold the brake pedal about 1/2 way to the floor. Use a prop rod for this purpose. This moves the master cylinder piston into position to block the fill port in the reservoir.
Sherwood
Old 04-22-2008, 12:14 AM
These are the hoses out of my 88 if that is any help.
Looks like that fitting on the right of your picture and the left on mine are slightly different but the vendor must have a plan.
Edit: Is there a slot for the U shaped spring in the upper bracket? Will it fit through the hole?
Rick
88 Cab
Old 04-22-2008, 09:07 AM
