-   -   By popular demand - tail light rebuild/LED conversion (http://forums.pelicanparts.com/porsche-911-technical-forum/405412-popular-demand-tail-light-rebuild-led-conversion.html)
slodave 06-10-2008 09:24 PM
I'm still the only one with the 'fly' (or is it sic?) LED license plate lights though... I know, envy of everyone.:cool:
http://forums.pelicanparts.com/uploa...1213158239.jpg
DRACO A5OG 06-10-2008 09:43 PM
I'm Green with Envy :p.
BTW, what type of bulb goes in there?
Mr.Puff 06-10-2008 09:48 PM
Can we see pics of your LED's in the day?
DRACO A5OG 06-10-2008 10:08 PM
Surething!
slodave 06-10-2008 10:21 PM
I don't remember, but they are now customized by me. It wasn't plug and play. If you remember, look at them Saturday.
DRACO A5OG 06-11-2008 04:59 PM
In Day Light:
Brake Lights Off
http://img.photobucket.com/albums/v5...DDayLight1.jpg
Brake Lights On
http://img.photobucket.com/albums/v5...DDayLight2.jpg
I thinks I need to use my Digital Camera, the cell is not that great, can't even see my third brake light
Mr.Puff 06-11-2008 07:40 PM
:P Yeah, the pics are too blurry to tell.
pope 06-12-2008 12:30 AM
You'll just have to hope that the lady following in that SUV doesn't have sight as blurry as that :p
dlague 08-08-2008 09:11 AM
here is another source of LEDs that I used for my 73. www.v-leds.com
I found them on eBay, but they have this site as well.
Their brake lights are very bright. Another interesting product is the resistors for the directional lights. With a pair of these you do not have to change your flasher. Just build the resistors into the rear housing. You use these ONLY on the directional lights! and just need one set per circuit left and right.
I wish I had seen this post before. I did essentially the same thing, but sort of made it up as I went along. I found a set of LEDs at a truck stop and that got me thinking. I had the car apart for paint anyway and I had one side market light not working and I knew the rest we dodgy at best.
I kept the original sockets and just fixed them up. Next time i may just do away with them and make the conversion electrically more solid.
By the way V-Leds also has some cool Xenon v-Hid kits for headlights....
The Curator 08-08-2008 10:09 AM
Originally Posted by Porsche-O-Phile (Post 3902486)
True on the LED lumens output. On that web site they do have "cluster" LEDs with I think up to 30 per cluster, which I considered, but I was concerned they might not fit. The 5 watt deals (the ones I used) are SUPPOSEDLY brighter than stock incandescent bulbs, but I haven't verified this. I sort of think they are, but not 100%.
I measured them and they are almost 20% brighter.
calling911 03-07-2010 09:23 AM
I know this is an old thread.. but I think a capacitor is what you want here.. Im not sure of the value.
dsmithwc04 07-18-2010 12:16 PM
Well, my tail light housing won't hold the bulbs tightly so i was thinking about replacing the holder part. I saw superbrightleds.com has the ba15 wired sockets so has anybody tried them in the 911 housing?
911pcars 07-18-2010 01:01 PM
Thinking about installing instrument panel lights in the tail light housing?
No. Not unless those behind you have the visual acuity of an owl or other bird of prey. The IP bulbs are quite dim relative to regular DOT-spec bulbs. Have you tried pulling the bottom contact of the socket outward a little? Some have tried depositing solder around the bulb base to increase the OD slightly.
Sherwood
PrecisionPete 08-22-2012 09:21 AM
Reviving an old thread...
I'd like to convert my 81 930 to LEDs - at least for the signals and brakes. Should be identical to a 911SC in this respect.
According to the schematics, these cars use a 4 pin flasher relay.
See: http://www.pelicanparts.com/911/911_parts/Electrical/911_electrical_78SC_USA.pdf
The extra pin seems to be required for the indicator lamps in the dash. So I don't see how a 3 pin flasher can work without rewiring.
Has anyone found a decent source for the electronic flasher relay? Or... How did you get it going with a 3 pin relay?
PrecisionPete 08-24-2012 07:36 AM
Nobody? Anybody?
Okay... Comparing the schematics from an 1981 to an 1985...
On the '81, the dash indicator bulbs are tied to pin C on the flasher module - presumable so they can indicate some sort of failure?
On the '85, the C pin is not used and the dash indicator bulbs just go to ground...
So... I presume I can just reroute the lead from pin C to ground and use a regular 3 pin european flasher module?
Here goes...
DRACO A5OG 08-24-2012 08:06 AM
Geez, hard to say, I don't think anyone has done this, just take care, and let us know the results.
We assume you have some electrical back-ground to attempt this task, right?
