Johnb911's Avatar
Fuel pump he questionlp
If I jump the fuel relay with 87a and 30.
Turn on the ignition.
Push up on the plunger it should spay??
I looked for a trouble shooting tread and did not find one.
I just replaced my injectors and seals two weks ago.
Ran great.
Put back in garage.
Son killed the battery with interior light trick.
Charged the car.
No fuel.
Help!
JOHN
79 EURO SC
"24 Years Later - The Dream Came True"
Old 04-13-2008, 02:16 PM
poorsha's Avatar
John,
I am subscribing as my 78 died in the driveway yesterday.
Sounds like fuel pump but my back is too sore for me to even spend any time on car.
I hope you get it running.
The weather is just starting to get nice.
Old 04-13-2008, 03:33 PM
CIS Trouble Shooting......
Ran great.
Put back in garage.
Charged the car.
No fuel.
Help!
John,
Bridging terminals #87a and #30 (FP relay) with ignition switch turn ON would cause the FP to run continously. Lifting the air sensor plate or FD plunger would cause the injectors to spray fuel provided you have sufficient system pressure!!! What's your system pressure? Did all 6 injectors fail to spray fuel? What year/model is your car? Keep us posted.
Tony
Old 04-13-2008, 05:08 PM
Johnb911's Avatar
Tony,
When I do the jump 30 and 87a the fuel pump does not come on in any key position.
Sorry for the confusion.
Also does not matter if I lift the plunger on the CIS.
JOHN
79 EURO SC
Old 04-13-2008, 05:43 PM
Fuel Pump ....
John,
Check your fuel pump. You will hear it make a buzzing sound when you bridge #87a and #30 (ignition switcn ON). If the pump is not making any noise at all, it could be dead or not getting power. Check the voltage across the FP terminals.
Bentley manual has some pictures showing the FP on pages 201-10, 201-12, and 201-14. HTH.
Tony
Old 04-13-2008, 07:17 PM
dshepp806's Avatar
Fuse OK?
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-13-2008, 08:19 PM
Al S's Avatar
John, I once had a situation where a piece of crud got into the pump and jammed it. On the bench, I was able to restart the pump in reverse, while applying compressed air to the outlet, and never had an issue afterward. Check the fuel tank strainer for blockage and any rust in the strainer outlet cavity. This area is often neglected on our cars.
Al Shkuratoff
86 Carrera, SW chip, Fabspeed, M&K
83SC Platinum - Sold
83SC Slate Grey - Sold
Old 04-13-2008, 08:44 PM
Johnb911's Avatar
Thanks Al,
I'll check that out when I get under there tonight.
JOHN
79 EURO SC
Old 04-14-2008, 08:58 AM
dshepp806's Avatar
or measure the pump's power terminals (if the fuse is too hard to check),..It will verify the entire power path to the pump..
I'd check the 25 A fuse first...
2 cents.
Middle Georgia
Old 04-14-2008, 12:22 PM
Pressure in the fuel lines doesn't mean that the pump is fine, it takes several hours (sometimes days) for the pressure to go down. On most cars if you turn the key to the run position without starting the car you can hear the pump run temporarily. Might even be your fuel filter or fuel tank too. Hope you fix your problem.
Old 04-14-2008, 11:17 PM
poorsha's Avatar
Any success yet John?
Old 04-16-2008, 07:15 AM
Johnb911's Avatar
Man.
I went out there last night ans just as an insane try I rejumped 87a and 30, tuned on the key and the fuel pump purred away.
WTH!
JOHN
79 EURO SC
Old 04-16-2008, 04:27 PM
poorsha's Avatar
John,
does this mean your relay is hooped?
Old 04-17-2008, 08:02 PM
Johnb911's Avatar
No.
It starts noe with the relay.
Freaken gremlems.
I am a liitle paranoid abouithe pump now and might just buy a back up before I go too far from home though.
JOHN
79 EURO SC
Old 04-17-2008, 09:08 PM
i use a razor blade to widen the pins on the relay for a good electric connection. The pins have a slot.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-18-2008, 09:17 AM
poorsha's Avatar
John,
what is the latest?
Car still running?
Old 04-24-2008, 07:21 AM
Johnb911's Avatar
I am going to insure it today so it's ready for the weekend.
It seems to be fine.
JOHN
79 EURO SC
Old 04-24-2008, 09:12 AM
Johnb911's Avatar
The final link in the chapter.
Well I started the car up friday morning (Beauty day to be alive)
Runs perfect down to the gas station for a fill.
Go to start. No Start. Jump the relay to listen for pump. No pump.
SH___T!
I can't beleive I let myself beleive it fixed itself.
Cal Lordco. they have a Bosch pump in stock.
$180.00 with my buddies discounts.
Have BCAA tow the car home that afternoon (two Blocks).
Get under the car and have the new one in and runing in about 1.5 hours.
WAY QUIET compared to he old one.
Had it out Saturday with the boys and it runs great.
It probably doesn't hur that I did the filter, injectors,seals, and injector sleeves all tis winter.
Thanks all for your help.
This chapter is closed.
JOHN
79 EURO SC
Old 04-27-2008, 08:36 PM
Al S's Avatar
Good news John, I'll see you out there! Once I get mine insured...
Al Shkuratoff
Old 04-27-2008, 08:39 PM
poorsha's Avatar
John,
glad to hear it all worked out (eventually).
Do you have the Bosch part # by chance?
Cheers.
Old 04-27-2008, 08:46 PM
