R&R front sway, bushing how to?
On the later 911's with the sway that dose not go through the trunk, how do you remove the front sway bar, install new bushings, & replace?
Do you have to disconnect one of the front A-arms? http://forums.pelicanparts.com/suppo...leys/smash.gif |
You don't have to remove an A arm, but it would probably help. Also, you might consider getting the Bently if you don't have one (it sounds like you don't - the R & R procedure is in there) as one of the things you'll need when you put it all back together are torque specs for all the bolts.
Also, try a search as there are a number of threads which have "tricks" to getting the front sway back in place. |
i've done this, and i would suggest dropping one a-arm to make it a lot more painless...also watch how the bar goes back in, as i once put mine in upside down :o
So the attachment point on the arms is not removable.
Guessing: Loosen lug nuts. http://forums.pelicanparts.com/suppo...leys/smash.gif Jack up car. Remove wheels, Note any pre-load on torsion bar at adjusting arm. Remove one A-arm from body. Let hang from strut. Remove straight section from near steering rack. Thread sway in or out of the other A-arm. Watch the direction so I do not have to do it twice. Rubber bushings have to be worked into place with effort. Am I missing anything? |
i also painted my sway bar, but that adds some drying time if you are in a hurry. |
| All times are GMT -8. The time now is 07:03 AM. |
