KLF911
Guest
Posts: n/a
Angry Broken Door Handle
How difficult to replace the inner door handle rod and plastic caps. As I opened the door the rod popped out and the plastic caps were broken (drivers side) Quick suggestions? Thanks!
Old 05-22-2001, 05:25 PM
BRAINIAC
Guest
Posts: n/a
Post
Which end broke? If it is the outer one, this is a piece of cake. If it is the inner one, you'll be taking off the door panel. This involves removing pretty much everything attached to the door panel.
Tyson Schmidt
72 911 Cabriolet
92 C-2 Cabriolet
Old 05-22-2001, 07:19 PM
BRAINIAC
Guest
Posts: n/a
Post
oops
[This message has been edited by BRAINIAC (edited 05-22-2001).]
Old 05-22-2001, 08:13 PM
rstoll
Guest
Posts: n/a
Post
Not too bad, even if you have to remove door panel. I replace the outer drivers side door handle on my SC a while back, in and out in about an hour. Replaced lock cylinder on passenger side about the same.
Robert Stoll
83 SC
83 944
Old 05-23-2001, 04:56 AM
