-   -   930 Trailing Arms (http://forums.pelicanparts.com/porsche-911-technical-forum/406335-930-trailing-arms.html)
martin_gibson 04-28-2008 01:12 AM
930 Trailing Arms
Searching through various threads on the subject:
I understand that to install late 930 trailing arms on a narrow body (72 c/w turbo flares) using the correct offset mounts, then the hub will end up moving approx 1" (25mm) to the outside.
Does this mean that a standard 11" Fuchs cannot be used?
Thx
Martin
MBEngineering 04-28-2008 04:59 AM
HI martin
with STD turbo arches , yes 11" wheel will not fit under.
regards mike
martin_gibson 04-28-2008 05:04 AM
Mike - thanks for confirming that.
Does anyone produce 11 x 15" Fuchs with a Turbo offset?
Martin
MBEngineering 04-28-2008 05:12 AM
HI Martin
try contacting neil from the site below, he may know or have some split rim 11 x 15" Fuchs from some track cars he has, with the correct offset.
http://www.bsmotorsport.co.uk/
regards mike
911teo 04-28-2008 06:31 AM
Martin
Jeff Alton is finishing up his forged Fuchs replica wheel. He will do a 15 AND a 17 in model. You'll be able to specify sizes and offset.
As per the timing.... I have no idea.
martin_gibson 04-28-2008 08:40 AM
Hi Matteo,
As we both know that has been and invariably will continue to be a 'very very' long wait? :)
Rgds
Martin
boba 04-28-2008 09:29 AM
Originally Posted by martin_gibson (Post 3911898)
Hi Matteo,
Rgds
Martin
I do believe it will be sooner than later. This photo is from another thread, and is the prototype.
http://forums.pelicanparts.com/uploa...1209400124.jpg
martin_gibson 04-28-2008 11:41 AM
http://forums.pelicanparts.com/support/smileys/clap.gif
