Guest
Posts: n/a
Any special information other thatn the 914 article that would help? Anything that I need in the back pocket (washers/selas etc) in case of need?
thanks. |
Guest
Posts: n/a
well, what article are you talking about? I upgraded my 66 911 to a split brake system. Had to run new lines, no big deal. The only catch I ran into was you have to modify the original pushrod. I has a "swollen" part in the middle that will keep you from pressing the brake pedal all the way, thence making bleeding it impossible.
