			 Porsche Owner
				996 tranny in 3.2 carrera
			so, im wanted to go to a six speed transmission in my 1987 carrera. wondering if a 996 transmission would fit? theres one at a local junkyard. let me know, thanks
	1987 Carrera - 2008 Cayenne Turbo  |
			The G50 6 speed from a 993 would probably be easier but still hard.  I bet this has never been done.  Interesting, definitely not a bolt up.
	erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold.  |
No!
	Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes |  |
			How about both tranny and engine from 996? With they fit in an older carrera?
	Fat butt 911, 1987  |
			 MBruns for President
			Just buy a 996 -  they are close in price these days.
	Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2  |
			The 996 transmission doesn't use the same bolt pattern as the 993 and older 911s. You can buy an adapter plate from Kennedy engineering. But that still leaves you a problem.....where do you put the starter.
			I researched this for a Boxster transmission installation into a 914/6. Same problems with the bolt pattern and starter. In your case you are probably better off getting a G50 6 speed from a 993 or 964.
	Clay Perrine 74 914 1.8L (Frodrick) 73 914 /6 4.0L 964 motor (Igor) 70 914 /6 Factory Six. (Elwood) 95 BMW 540i (Inga)  |
	Tony G 2000 Boxster S  |
			 durn for'ner
			Still, you have a precious G50! Think of us poor sods negotiating a 915!
	Markus Resident Fluffer Carrera '85  |
			Why the huge desire for a 6-speed.  In 996 guise it would not offer that much more from a performance standpoint, probably less as it weighs more.  You would probably need to replace all the gearing to fit the 3.2 torque output as well.
	Only benefit I see from a 6 speed is that you can keep the 6th ratio high (for cruising) while still maintaining 5 ratios that can be performance oriented. 6th would not really have to be "designed" to fit with the other ratios.  |
