AutoBahned
spline lube ??
clutch package has a small (McDonalds ketchup pac size) amount of Sachs spline lube with it.
The diagram on the pac is uninterpretable. Where exactly are you supposed to put it? And on what surface is it really goes on the fingers of the diaphragm...? |
gearhead
It's for the output shaft splines where the clutch disc slides back and forth. Do NOT put that on the tongues of the pressure plate...
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
AutoBahned
Thanks! I already used Mb grease (Swepco) on those.
Maybe I can put it on eBay for $999.... |
