constaf's Avatar
915 Trans, Ring and Pinion Question
What performance difference would i notice by going from a 8:31 to a 7:31 ring and pinion on my 1980 SC?
thanks
Old 07-11-2007, 07:54 AM
constaf's Avatar
thanks. Do you know where i can find their comments?
Fred
Old 07-11-2007, 08:17 AM
Work in Progress
Rich76_911s's Avatar
Here is a great article on it by Noah:
http://www.dorkiphus.net/porsche/showthread.php?t=8642
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 07-11-2007, 08:24 AM
constaf's Avatar
awesome article. awesome. I got the information that i was looking for.
Old 07-11-2007, 08:37 AM
Cory M's Avatar
here's some reading material for you (I'm going to be doing the same r&p change soon too):
7:31 R&P torque capability or 8:31 gearing issue
7:31 vs 8:31 ring and pinion
915 R&P Whine - How do you get rid of (fix) this??
Best Year for a 915 Transmission?
All the Way Into 915 & Comin Out (Long)
Old 07-11-2007, 08:52 AM
Bill Verburg's Avatar
Re: 915 Trans, Ring and Pinion Question
thanks
It depends on what you are looking for,
a drag racer? sure it would probably help
dual purpose?
ok but not great on track, ok but busy on the street
dedicated track car?
no way
here is what a stock 915/63 used n "80 -81 US SC looks like
And here is a 915/63 w/ 7:31
Compare top end, drops through the gears, speed in gears and speed at ~2k. Those are the main factors to consider
Besides the fact that you lose a little reliability, probably not an issue w/ a 3.0 though.
Bill Verburg
Old 07-11-2007, 09:37 AM
chrisp's Avatar
another way to look at this is if you run 22" diameter tires (versus the stock 25") you'll get the same affect, feel like you have bigger brakes, have a much lighter wheel/tire combo, etc.
Something like a 225/40-15 and 245/35-15 would be perfect.
'83 SC
Old 07-11-2007, 09:46 AM
chrisp's Avatar
Bill, how about a bigger tire. Figure it for 25" and also 25.5" if you could. Most commonly used DOT-R race tires run within these diameter limits.
Topping out at 130 mph is a definite problem on track.
'83 SC
Old 07-11-2007, 09:50 AM
I know it says 245/45x16 but the dynamic loaded rolling radius of the tire is what is important.
24.5" is the # to use in this app to aproximate a 265/35 x18 tire
a 245/45 x16 would need ~23.9"
a 275/40x17 ~24.9" etc.
Bill Verburg
Old 07-11-2007, 10:36 AM
constaf's Avatar
Re: Re: 915 Trans, Ring and Pinion Question
Thanks. But then why is a 7:31 r&p ratio considered an upgrade by PCA club racing rules? Is it because you will get a quicker initial acceleration or because you can stay in 3rd gear more consistently instead of waisting time down shifting to 2nd?
dual purpose?
no way
Old 07-11-2007, 11:21 AM
constaf's Avatar
I just sold my 1985 Carrera and bought a 1980 SC. If the SC has a 8:31 ratio, will it feel different than the Carrera? Some other posts suggest that it will. Thanks
Old 07-11-2007, 11:29 AM
Re: Re: Re: 915 Trans, Ring and Pinion Question
Thanks. But then why is a 7:31 r&p ration considered an upgrade by PCA club racing rules? Is it because you will get a quicker initial acceleration?
PCA stock classes are stock, Yes, While in a given gear you get quicker acceleration but at a lower speed, the penalty is the shortness of the gears which on a track means more shifting. There is no improvement in the rpm drop between gears.
What you want is to decrease the rpm drop between gears, this does the same as lowering the cwp ratio and keeps the rpms in the fattest part of the power band more of the time.
As always the other penalty is higher revs at highway speeds.
Here is something that has the best of both worlds. stock 915/63 w/ short 3, 4, 5
Bill Verburg
Old 07-11-2007, 11:45 AM
An '85 US CArrera has a 915/68 which is geared identicaly to a 915/63 in an '80 except that the 915/68 has a taller 5th
The feel through the gears then depends on the relative weights and torque characteristics of the engine. Shoud be pretty similar though except in 5, where the Carrera will feel slower at a given speed.
Bill Verburg
Old 07-11-2007, 11:53 AM
Hello M. Verburg
Do you have the same charts for an euro carrera (1974), and the 73 RS ?
those are nice !
thanks
Philippe
Old 05-08-2008, 07:10 AM
fun around town, higher revs and poor mileage on the freeway. i've done it and gone back to the 8:31.
206 637 4071
Old 05-08-2008, 08:26 AM
Originally Posted by philippeF View Post
Hello M. Verburg
those are nice !
thanks
Philippe
'73 2.7RS 915/08
'74 2.7RS 915/06
Bill Verburg
Old 05-08-2008, 03:44 PM
thanks again
Philippe
Old 05-09-2008, 02:46 PM
