Better chances at passing emissions
Adding 1.5 to 3 ounces of pure acetone to every 10 gallons of fuel will:
1) Cut your emissions by half 2) Improve your gas milage considerably 3) Improves performance. |
Do you have any data to back up these claims?
4) It will eat your rubber fuel lines.
why my car is 38yrs old;)
The statement is obviously bullpucky just by looking at the physics of it.
#1 - It is technically possible that something could effect the burning process to increase the cleanliness but with no proof... All I can say is this is what he is trying to infer is true by using the other statements as support. So lets look at the other statements. #2 - To increase the gas mileage with an additive it must either increase the quantity of BTUs per gallon by a notable percentage or make a major change to the basics of the Otto cycle. This claim falls on its face... hard... #3 - The response to this is basically the same as #2. The end result is BZZZZZTTthankyouforplaying. Oh and #4 sounds spot on. :D |
He forgot to add:
Will not work without a 'Cool Collar'. |
Eating beans always helps me pass emissions.
:D |
Acetone improves surface tension. It does not eat rubber fuel lines. Additionally, it
burns hotter! |
Some interesting reading here about the subject.
http://www.chemicalforums.com/index.php?board=5;action=display;threadid=2517 |
Previously failed emissions with 2200 HC, co was at 6.1. I added 1 gal of regular
gas and 17cc of acetone to the tank. Drove back to the emissions station and re-tested. PASSED! The results were 1200 HC and 4.23 co. My motorcycle seemed to run better as well. 78 Kawasaki Z1-R 81 911 sc 76 911s 79 930 70 914 66 912 v8 67 912 |
At 12-15 cc per gallon of fuel it's NOT going to dissolve anything! |
Ok, I'll take your word for it.
acetone, do you mean the stuff ladies use for their finger nails?
http://www.mgexperience.net/article/co-afr.html I would opt to try and get my tune to be more stoichiometric….. |
| All times are GMT -8. The time now is 07:26 PM. |
