Better chances at passing emissions
Adding 1.5 to 3 ounces of pure acetone to every 10 gallons of fuel will:
1) Cut your emissions by half 2) Improve your gas milage considerably 3) Improves performance. |
Designer King
Do you have any data to back up these claims?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
The Puff.
4) It will eat your rubber fuel lines.
N-Gruppe doesn't exist
why my car is 38yrs old
Ted '70 911T 3.0L "SKIPPY" R-Gruppe #477 '73 914 2.0L SOLD bye bye "lil SMOKEY" ![]() "Silence is Golden, but duct tape is SILVER.” other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L |
Diss Member
The statement is obviously bullpucky just by looking at the physics of it.
#1 - It is technically possible that something could effect the burning process to increase the cleanliness but with no proof... All I can say is this is what he is trying to infer is true by using the other statements as support. So lets look at the other statements. #2 - To increase the gas mileage with an additive it must either increase the quantity of BTUs per gallon by a notable percentage or make a major change to the basics of the Otto cycle. This claim falls on its face... hard... #3 - The response to this is basically the same as #2. The end result is BZZZZZTTthankyouforplaying. Oh and #4 sounds spot on.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Slumlord
He forgot to add:
Will not work without a 'Cool Collar'. |
Eating beans always helps me pass emissions.
Carrera 3.2 - "Faster, Stronger, Better" Last edited by bonkers; 05-12-2008 at 07:51 PM.. |
Acetone improves surface tension. It does not eat rubber fuel lines. Additionally, it
burns hotter! |
Driving member
Some interesting reading here about the subject.
http://www.chemicalforums.com/index.php?board=5;action=display;threadid=2517
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
Previously failed emissions with 2200 HC, co was at 6.1. I added 1 gal of regular
gas and 17cc of acetone to the tank. Drove back to the emissions station and re-tested. PASSED! The results were 1200 HC and 4.23 co. My motorcycle seemed to run better as well. 78 Kawasaki Z1-R 81 911 sc 76 911s 79 930 70 914 66 912 v8 67 912 |
The Puff.
At 12-15 cc per gallon of fuel it's NOT going to dissolve anything! |
The Puff.
Ok, I'll take your word for it.
acetone, do you mean the stuff ladies use for their finger nails?
Fat butt 911, 1987 |
Wearing Pants
http://www.mgexperience.net/article/co-afr.html I would opt to try and get my tune to be more stoichiometric….. |
