-   -   RS Ignition Curve (http://forums.pelicanparts.com/porsche-911-technical-forum/409012-rs-ignition-curve.html)
Fishcop 05-13-2008 01:20 AM
RS Ignition Curve
Hi Guys
Any chance someone has an ignition graph or table for a stock RS spec engine to assist me have a distributor recurved?
BURN-BROS 05-13-2008 06:12 AM
http://forums.pelicanparts.com/uploa...1210684351.jpg
moneymanager 05-13-2008 07:56 AM
I have seen RS specific curves either here or on early 911S registry in last couple of days. Sorry, can't give you the address.
911pcars 05-13-2008 08:07 AM
Here you go:
http://forums.pelicanparts.com/uploa...1210690736.jpg
Sherwood
RoninLB 05-13-2008 08:10 AM
Aaron's chart "2.7 Carrera", + 2.7 Euro, and 2.7 RS are all same. Cost new should be around $300us. Call pelican and tell them the cheapest price you could find. They don't list the 004 in their catalog. You can run 10deg initial and max at 35deg without vacuum connected.
http://forums.pelicanparts.com/uploa...1210691441.jpg
911pcars 05-13-2008 08:28 AM
Ron, Aaron,
So as not to confuse, the advance numbers in the chart I posted describe distributor advance only. Distributor degrees are 1/2 crank rotation degrees (rotates at 1/2 speed).
Your charts describe total ignition advance (distributor advance + initial static timing, an additional 10º).
Same numbers in the end.
Sherwood
BURN-BROS 05-13-2008 05:53 PM
Originally Posted by 911pcars (Post 3939538)
Ron, Aaron,
Sherwood
Correct.
Fishcop 05-14-2008 01:33 AM
Thank you very much gents, just what I needed.
