Bird. It's the word...
Fishcop's Avatar
RS Ignition Curve
Hi Guys
Any chance someone has an ignition graph or table for a stock RS spec engine to assist me have a distributor recurved?
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 05-13-2008, 01:20 AM
BURN-BROS's Avatar
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 05-13-2008, 06:12 AM
moneymanager's Avatar
I have seen RS specific curves either here or on early 911S registry in last couple of days. Sorry, can't give you the address.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 05-13-2008, 07:56 AM
Here you go:
Sherwood
Old 05-13-2008, 08:07 AM
Aaron's chart "2.7 Carrera", + 2.7 Euro, and 2.7 RS are all same. Cost new should be around $300us. Call pelican and tell them the cheapest price you could find. They don't list the 004 in their catalog. You can run 10deg initial and max at 35deg without vacuum connected.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-13-2008, 08:10 AM
Ron, Aaron,
So as not to confuse, the advance numbers in the chart I posted describe distributor advance only. Distributor degrees are 1/2 crank rotation degrees (rotates at 1/2 speed).
Your charts describe total ignition advance (distributor advance + initial static timing, an additional 10º).
Same numbers in the end.
Sherwood
Old 05-13-2008, 08:28 AM
BURN-BROS's Avatar
Originally Posted by 911pcars View Post
Ron, Aaron,
Sherwood
Correct.
Burnham Performance
Old 05-13-2008, 05:53 PM
Fishcop's Avatar
Thank you very much gents, just what I needed.
John Forcier
Old 05-14-2008, 01:33 AM
