Location: Originally from Orlando, now Halifax, Nova Scotia.
Passenger door won't open from inside
I am not really sure if it was like this since I bought the car in October 2007 ( Wife never rides in it, therefore I haven't really opened the passenger door too much from the inside). The problem is that, after I unlock it and pull the handle, nothing happens. However, the door will open from the outside with no problems.
The problem is, when I bought the car, the power window for the passenger side was working intermittently, but now is not working at all, so I cannot even put the window down and stick my hand outside to open the door. Every time when I have someone else in the car ( not often), I have to get out, like a nice gentleman, and open the door from the outside. Any ideas of what can be the cause of this?
Now, the passenger power windows...that's another issue...probably bad switch.
Old 05-17-2008, 05:47 PM
Southern Class & Sass
Dixie's Avatar
I had some trouble opening the driver side door on my '88 recently. It seemed to be sticky. What I found is the "Bowman Cable" that pulls the catch from inside had stretched. As a temporary work-around, I spaced the door panel away from the door using some washers.
I have a new cable on order via Pelican. Once I have the door opening issue resolved, I think I'll spring for fresh door panels and speakers. Just because the car spends most of it time on race tracks doesn't mean it can't be really nice.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 05-17-2008, 06:07 PM
