kcf7z's Avatar
Relay socket insertion help
This should not seem to require help, but I am in the midst of installing a relay socket into an empty hole for a cooling fan for a new carrera cooler and try as I might I cannot get it to pop through from behind. Is there a trick to this that I am not seeing. The socket does not seem to come apart and All I am currently doing is marring up the hole and the socket with a flat head screwdriver trying to get it in place. I have decided to stop work for tonight. Probably dumb question, but any help wold be appreciated.
Old 05-15-2008, 08:07 PM
jeff1hughes's Avatar
I honestly would have to look but, not to imply any better knowledge, have you tried turning it 90 degrees? It's possible that it is not exactly square.
86 Carrera Targa - Garnet Red Metallic
88 928 S4 - Gran Prix White
Old 05-15-2008, 08:14 PM
Mitch Leland's Avatar
I'm assuming you working on the left side, engine room panel... First be sure that your battery is disconnected before messing with the relays. "don't ask me how I know"... The relays on my "84" the base and relay do not separate like a traditional base socket.
Hopefully someone will chime in with more knowledge...
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 05-15-2008, 08:17 PM
kcf7z's Avatar
It is one of the round relays on above the main fuse panel. The relay socket looks like it should just snap in from behind like the others and Wayne's book does not suggest any difficulty with this process - I probably either need to drink more milk or hire a gorilla, but all I know is my fingers are sore with m failed attempts.
Old 05-15-2008, 08:22 PM
Do you really think that milk will make you think you got it in all the way? How about something stronger, like Tang, I hear it works for astronauts.
Old 05-15-2008, 08:48 PM
kcf7z's Avatar
I'll reask for all the east coast folks that were'nt perusing after 11:00 last night. Thanks.
Old 05-16-2008, 05:19 AM
MBAtarga's Avatar
I added a relay socket to my fuse panel during the oil cooler fan upgrade on my SC.
I stuck it through the existing hole and twisted it, maybe even helped it through by pulling it from the front side.
Mark
'83 SC Targa - since 5/5/2001
Old 05-16-2008, 05:36 AM
kcf7z's Avatar
That's what it looks like. Maybe I need to use more umph. I just got through with surgery for the day - you would think if I can do that - I should be able to snap a relay in place...
I'll go home and try again.
Old 05-16-2008, 01:19 PM
Tree-Hugging Member
Jim727's Avatar
If you're talking about the factory-type round relay (sounds like you are), there is a cavity in the center which creates a hollow in the mounting nipple. You need a rounded tool, like a rounded dowel, which inserts into the cavity and is used to stretch the mounting nipple. Silicone the rubber and metal bits and press the relay socket gently into the hole with the tool. Do Not use anything sharp or it will penetrate the rubber and you're right back to using a screwdriver.
Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners.
Old 05-16-2008, 02:32 PM
Designer King
Paulporsche's Avatar
I'll go home and try again.[/QUOTE]
You gotta love it! Here's a guy who performs surgery yet can't do what seems like a simple task on a car whose fusebox design goes back to an old sawmill in the mountains in the thirties!
It's a good thing we love these cars.
Keep at it. The previous suggestion sounded like a good one. And don't forget...we're laughing (crying?) with you, not at you.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-16-2008, 02:58 PM
kcf7z's Avatar
There is an art to everything.
There is the proper technique of which experience is the best teacher and having seen it done or done it before makes a big difference.
Surgery is easy - working on these cars is my way of reducing stress - funny thing to pick huh?
Old 05-16-2008, 05:09 PM
I'm confused.........if we're talking about the round relay receptacles...heat them up a bit with a hair drier...softens the rubber up a bit, and they snap into place pretty easily then. Be careful not to get them too hot, they also tend to deform or melt. As I recall I inserted mine from the front, not behind, but maybe it doesn't matter.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 05-17-2008, 11:41 AM
