Stop fronting.
Installing CBP on '86 3.2, Need New Nuts & Bolts
After a couple of hours of battling with the stock hardware, I was finally able to remove the cat from my '86 3.2.
Obviously, I cannot reuse the stock nuts and bolts. Any suggestions or recommendations on where I can find the correct hardware, and/or what size(s) I should be looking for? Thanks! Chris
Chris Harrell '72 914 1.7 Saturn Yellow, '73 911T-RS Coupe Red |
E-85 sippin drunk
Fastenal, Lowe's, Home Depot, Tractor Supply, Ace Hardware, or any other place that has metric bolts and nutz.... They are nothing fancy, all you need to do is bring your old bolts and such down there, and they will fix you up....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
Stop fronting.
Thanks.
Got them and all wrapped up with the job. Chris
