Question on AC removal / dash
Hi guys - happy to say this is the "before" picture but it was the best one I have of the AC vents.
Newbie here, so thanks in advance for the patience, but am I correct in that the lower dash extension and vents are aftermarket for my 1974? Can I simply remove all of this if I'm not going to use the AC?
Thanks.
Old 10-29-2011, 07:04 AM
Porchcar guy's Avatar
Simple answer is yes but you would also need to delete the rest of the system to be correct, condenser, evaporator, compressor, drier, hoses and all lines. Save what you can as the parts may be saleable.
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 10-29-2011, 09:19 AM
Got it - and will save everything.
Thanks.
Old 10-29-2011, 10:51 AM
Reifle's Avatar
Once you take it all out I believe there are knee bolsters that finish it off real nice - I think they are hard to come by though. I t just round off the edge once you remove the A/C vents and housing.
'77 Porsche 911S
Old 10-29-2011, 10:59 AM
Thanks - once the lines are disconnected should this just lift out of the smuggler box?
Old 10-29-2011, 11:09 AM
Simple answer is ---YES
15 year PCA member
Old 10-29-2011, 11:23 AM
Just laying around Kansas
Prairie Lizard's Avatar
I read a recent post where the same question was asked. They mentioned there were screws under the dash also. I haven't taken mine out yet, so I'm curious what you find out.
Rick Ralston
1973.5 911 T
RSR wannabe
Old 10-29-2011, 12:43 PM
Hi Rick - mine was a mix of metric and standard bolts and screws. Typical of the DPO, sigh. Not sure what you will find.
I still need to take the rest of system out, will take pictures.
Still need to test Bob's tach adapter but couldn't dig into electrical system since car is at the body shop for rocker repair.
Old 10-29-2011, 12:59 PM
