Quick CIS question
I'm a rookie with CIS and just need a little clarification.
Am I right in thinking that the mixture adjustment only adjusts the mixture in the warm up phase, and when the engine is warm or higher than idle the O2 sensor and the Lambda take care of all mixture adjustments?
'82 911 SC |
The 3 mm allen screw in the fuel distributor adjusts mixture across the board.
O2 and cat will attempt to adjust but can only do so within a limited range. Warmup mixture is controlled by the warmup regulator (WUR). ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
O.k. I see, that's why you make sure to have a warm engine to adjust the mix. Thanks!
'82 911 SC |
Thread Tools | |
Rate This Thread | |
