-   -   Diagnose Spark Plug - Something's Wrong (http://forums.pelicanparts.com/porsche-911-technical-forum/410880-diagnose-spark-plug-somethings-wrong.html)
vesnyder 05-23-2008 10:43 AM
Attached is a plug I just removed from my rebuilt motor - about 600 miles - and my milage (MPG) is horrendous. Any ideas?
http://forums.pelicanparts.com/uploa...1211564607.jpg
stlrj 05-23-2008 01:16 PM
Now you need to find out why it's running so rich. Things to check might begin with the frequency valve operational, 02 sensor, dome light working? Or take it to a wrench who's familiar with these hints.
David 05-23-2008 04:37 PM
Do all the plugs look the same?
vesnyder 05-23-2008 04:40 PM
I actually ran it on teh freeway then shut it down without taking it to idle and snapped th epic then - so I only checked one plug. Whan I changed the plugs about 200 miles ago they were all similar.
Zeke 05-23-2008 05:34 PM
That explains to me why the plug and black and white at the same time. Is the O2 sensor hooked up? I guess you ought be chasing idle mixtures because the freeway RPM is actually lean.
that didn't make any sense, did it?
cgarr 05-23-2008 06:46 PM
Get more miles than 600 on it. I assume this is you SC and not the 914?
snbush67 05-24-2008 03:02 AM
Maybe its the angle of the photo but that gap looks a little tight, are you getting higher then normal engine temps?
