Diagnose Spark Plug - Something's Wrong
Attached is a plug I just removed from my rebuilt motor - about 600 miles - and my milage (MPG) is horrendous. Any ideas?
Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD |
Now you need to find out why it's running so rich. Things to check might begin with the frequency valve operational, 02 sensor, dome light working? Or take it to a wrench who's familiar with these hints.
Do all the plugs look the same?
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
I actually ran it on teh freeway then shut it down without taking it to idle and snapped th epic then - so I only checked one plug. Whan I changed the plugs about 200 miles ago they were all similar.
That explains to me why the plug and black and white at the same time. Is the O2 sensor hooked up? I guess you ought be chasing idle mixtures because the freeway RPM is actually lean.
that didn't make any sense, did it? |
abit off center
Get more miles than 600 on it. I assume this is you SC and not the 914?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Maybe its the angle of the photo but that gap looks a little tight, are you getting higher then normal engine temps?
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
