Max Sluiter
My RPM transducer/speed switch is faulty. How should I go about disassembly, inspection, and repair? I see that there are a few transistors that commonly break loose from their solder joints due to vibration. Can I just re-solder and then try an RTV coating?
The unit failed the test of raising the rpms to ~2000 with the hand throttle, then manually activating the microswitch while the hand throttle is still raised. The rpms did not fluctuate according to the microswitch. They dropped ~200 after a few momwents and stayed there until I released a little tension on the hand throttle and then pulled it all the way up again. All the while, my friend was pushing the microswitch and releasing it with intervals of a few seconds. The rpms did not correlate to the microswitch and did not fall and rise again as the fuel was cut off and the idle circuit then catches it on the low end. The engine is a 2.7 liter RS spec and it was up to temperature when the test was done. It idles a little high when warm ~1500 rpm. It pops through the exhaust on over-run after aggressive driving, in addition to the normal ticking through the intake. I have the RPM transducer schematic from the ultimate MFI resource thread. How should I go about fixing the problem? Any info is greatly appreciated.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Max Sluiter
motivation for the helpers
Try this For MFI Gurus. . .and friends of Warren . . .
Do a search, the answer is there somewhere. ![]() ![]() Romove the transducer, pry up tabs, slide out circuit board, start soldering.
Mike '99 Isuzu VX, 2005 Audi A4 1.8T Quattro '96 BMW 328ic '73 911T Targa SOLD www.flickr.com/photos/fenderbender813 |
This is all you need to know thanks to the wonderful info provided for years here by the departed and most respected of our members, Warren Hall, Jr. aka Early_S_Man.
__________________ Warren Hall, Jr. |
Max Sluiter
Thanks for the replies
Max Sluiter
I disassembled the unit this afternoon. The contacts all appear to be solid.
I am going to clean the copper contacts and the relays. I will warm the solder joints. Hopefully this will get it to work. I have not seen this type of 2 relay circuit layout in the photos of others' restorations. Anyone have the same thing? ![]() ![]() ![]()
???? Is that the two stage defroster relay ??
those dirty connections look suspect.
I don't think that's the RPM transducer...looks more like the rear defrost relay. Also, "Heckscheiben Heizregler" translates as Rear Window Heat Regulator.
______________________________ Dave 1969 911T Coupe 1972 911E Targa Last edited by dafischer; 05-28-2008 at 07:21 PM.. |
Tree-Hugging Member
Genau!
~~~~~ Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners. ~~~~~ |
Max Sluiter
Ach du Lieber
Max Sluiter
3rd attempt to post
This box was in the #6 defroster location in the diagram, after all. There was nothing in the #5 RPM transducer location on the diagram. I now see why the motor was backfiring on engine braking.
Anyone have a working RPM transducer? Trade for a 2 stage rear defroster. I have Lexan windows. I don't need a defroster but I would like an RPM transducer. ![]() ![]()
Tree-Hugging Member
Otto's, in Venice rebuilds them. 310-399-3221
You will be very much in their better graces if you can find something at a recycler to provide them as a replacement to rebuild!
