ajmarton's Avatar
89 911 Cab - squeaking sound when air is on.
I have a strange situation. It seems that the AC fan squeaks when the 911 is in a turn or moving. It goes away when I come to a full stop. It is not very loud and is intermittent. It almost seems like the fan is out of balance. I thought it was the suspension at first but the squeak goes away if I turn off the AC while the car is moving. Has anyone had a similar situation before I start on this project.
Old 05-27-2008, 09:16 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Yeap, same sound here too.
Most likely the fan motor rubbing against the housing internally. Mine makes the sqeeking sound in level 2.
'85 Carrera Targa
PCA/POC
Old 05-27-2008, 09:21 PM
dorschman's Avatar
I read some posts about opening up the smuggler's box, finding the big black fan housing, taking the screw on top out and putting a couple of drops of oil in there. I had a squeak that sounded like a little bird chirping. Went away with a couple of drops of oil.
erik
87 911 coupe "Katy"
Summer Yellow
Linen Mahogany interior
04 Pilot "The Pilot"
Old 05-28-2008, 04:00 AM
ajmarton's Avatar
Thanks. I will give it a try over the weekend. Oiling it sounds promising. I suspect part of the problem is that I am driving the 911 on a regular basis where the prior owner did not use it much. Consequently, I have had to replace the foot well fans and the blower in the engine compartment as well. I suspect this one may be dry or ready to go.
Old 05-29-2008, 12:11 PM
