Registered Abuser
MT930's Avatar
Suspension Lube Tips ?
Any tips on lubing suspension. Grease type , points and areas. I's starting to make some noise.
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 08-28-2008, 05:54 PM
3.2 CAB's Avatar
Mike, AKA Lubemaster, has some great products for the lubrication of your vehicle. As far as what needs what, a Bentley Manual will help. Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 08-29-2008, 06:28 AM
AutoBahned
RWebb's Avatar
stock susp. has NO lube points.
squeeking may be rubbing caused by cold flow failure of old bushings
if not stock, may be nasty polygraphite aftermarket bushings that want to be replaced...
Old 08-29-2008, 07:23 PM
Max Sluiter
Flieger's Avatar
squeaking with factory rubber bushings is usually actually the torsion bars rubbing on their housings because the bushings have flowed. This means torsion bar replacement $oon.
Old 08-29-2008, 08:26 PM
I use a syringe with synthetic oil in it to squirt/lube all the bushing crevices, synthetic oil will not attack rubber.
Old 08-29-2008, 09:17 PM
Registered Abuser
MT930's Avatar
I found the Zerk fittings, what type of synthetic grease should I buy? It is red in color, high pressure ? I have the gun. Elephant Racing type bushings.
MT 930
американский
Old 09-06-2008, 07:27 PM
