Tony
Maxhouse97's Avatar
Why did Porsche not want my electric oil cooler fan to come on until 244 deg?
I was sitting in traffic on Friday (summer has arrived in VA) with the a/c on and the oil temp got real close to the second white hash mark (around 248 deg). I never heard the fan come on. So I came back and looked up what temp the fan is supposed to come on - at found out that its 244 deg F. Even though the red part of the gauge doesn't start until 302 deg F, people here say you should get over 250.
My question is why would the factory set the thermoswitch temp so hi? They must have had a reason.
I have read about swapping the thermoswitch for a BMW part that opens at 230. Others have wired a manual switch. I am thinking about the former.
Thing is that Porsche engineers usually have good reasons for what they do - any ides?
Tony
22 GT4
04 E46 M3
87 Carrera (sold - craving aircooled again)
12 991 Carrera (sold)
Old 06-08-2008, 02:38 PM
old man neri's Avatar
I think it is just a simple wire slice to have it run all the time with the engine on. That is one option to look at.
Old 06-08-2008, 02:57 PM
Tony,
Porsche allowed these engines to run that hot for emissions compliance.
They are not as concerned about engine longevity and durability.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-08-2008, 03:04 PM
I have heard that the fan is not a real long lasting unit. If you run it all the time it will fail soon. My 85 Carrera did not come with a fan. I added a fan and just put in a toggle switch. If the temp is over 200, on goes the fan. I figure it is a human interface temperature switch. I never need it in the winter months.
Old 06-08-2008, 03:40 PM
Tony
Maxhouse97's Avatar
I was thinking of installing the bmw 99 deg C (210 F) thermoswitch - I like the idea of an automatic switch rather than a manual just in case my wife is driving the car.
That still seems so hot - emissions or not.
Tony
22 GT4
04 E46 M3
Old 06-08-2008, 08:04 PM
I've heard about that lower temp switch. But, what BMW switch is that specifically?
thx
todd
89 targa
Old 06-08-2008, 08:16 PM
Send a message via AIM to fintstone
Most folks install both. You can switch on the fan anytime you want...but if you forget, it will come on when the temp exceeds 210F.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 06-08-2008, 08:17 PM
I understood the fan only delivers adequate cooling when the oilcooler is really hot.
carrera coupe 85
Old 06-09-2008, 01:53 AM
Barrpete's Avatar
I installed the fan kit from Elephant Racing. It comes with an adjustable thermostat. IIRC The range is something like about 170 to 280 F.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 06-09-2008, 07:14 AM
I would think you should see at least 212- degrees to get any moisture out of the engine. You can run too cool. There's an optimum temperature. To cold is as bad as too hot.
You engine makes it's best power running a little on the hot side. In fact most engine show peak horsepower just before they blow up - but that's another story.
Richard
Old 06-09-2008, 07:20 AM
Tony
Maxhouse97's Avatar
Richard,
That goes back to th original question - maybe its no so bad to run around at 250 degrees if the factory didn't have the fan come on until 244 and the red line is placed at 300. I know I get nervous when the needle gets there, but maybe I shouldn't.
I have to check the owner's manual to see if it says anything...
Tony
22 GT4
04 E46 M3
Old 06-10-2008, 04:18 AM
Richard
Drop some water on the pavement on a 100 degree day and watch how fast it evaporates. It does not have to get to boiling temp to purge the moisture. In the winter time the engine temp simply will not go above 185 on my 911. I don't worry about it. That is plenty hot enough to purge any water. The thermostat controls the oil going to the front cooler. Until it send oil up front the fan is useless. The front cooler is never going to make the engine temp get to cold. Your engine will last a lot longer at 225 instead of 250. 260 is flat out to damn hot.
Old 06-10-2008, 06:04 AM
