XLR8'd Member
David 84 911's Avatar
Sand Blasting fan housing
Anyone ever have sand blasted a fan housing witout damaging it? I know the fan itself is too fragile but not sure about the housing. I prefer not to go the route of glass beads as I have no one close to me that does it.
David (mechanic wanabe)
2002 Carrera 4S (replacement for an 84 coupe)
06 Acura CSX (wife beater)
05 Acura MDX (toy hauler)
http://www.pelicanparts.com/gallery/david_84_911
Old 03-18-2008, 08:17 AM
GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
I've sand blasted them before painting them and had no problems. You may find some pitting in the aluminum due to age.
Old 03-18-2008, 08:35 AM
XLR8'd Member
Thanks. Glad to be reasurred.
Old 03-18-2008, 08:48 AM
jonbot's Avatar
I sandblasted mine, then applied a coat of clear:
- Everything's easier once you get started. -
'95 993 C2
'73 911 Targa
'88 BMW M3
'84 Mercedes 190e 2.3 16v
Old 03-18-2008, 08:52 AM
I would rather be driving
jpnovak's Avatar
YOu only want to clean the surface. Just drop the outlet pressure to about 55-60 psi. works great.
Old 03-18-2008, 08:56 AM
The Chef
Guest
Posts: n/a
I had mine done with walnut shells then tumbled. The tumbling smooths out the pores a bit. You may want to coat with some silicon or something to keep from oxidizing. Hope that helps.
Old 03-18-2008, 09:01 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Dave....is this 911 will be ready in time for the F1 Grand Prix gather....?
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 03-18-2008, 09:25 AM
XLR8'd Member
Finally found a second to post a pic of the finished product. Thanks all.
Old 06-01-2008, 12:44 PM
As a note, I am in the process of trying to weld/ grind/ weld/ grind mine. I have found that the cast magnesium is very porous. I'm filling in the voids with magnesium welding rod, and it's really tough going. If you remove too much surface metal, then you are down into the air bubbles, and your fan housing will start to look like swiss cheese. I'd say you have to be very careful with any type of medial blasting.
I'd recommend using the least aggressive techniques available.
Old 06-01-2008, 01:42 PM
