-   -   carrera throttle linkage issue (http://forums.pelicanparts.com/porsche-911-technical-forum/412320-carrera-throttle-linkage-issue.html)
jmshepard 05-31-2008 04:31 PM
I am trying to use a Carrera Intake on my SC. I have run into a problem with the linkage.
The intake manifold and throttle body are both from a source that is different from the throttle linkage plate. It could be a mismatch of year groups, but I can't determine this from the PET illustrations.
I have swapped out the linkage/bell crank plate on the engine case with a Carrera version, however the linkage that came with the TB seems to have the socket for the ball joint on the wrong side of the push-pull rod. I would appreciate some guidance on this one.
Thanks,
Jim S.
http://forums.pelicanparts.com/uploa...1212276405.jpg
http://forums.pelicanparts.com/uploa...1212276508.jpg
http://forums.pelicanparts.com/uploa...1212276569.jpg
purplehaze 05-31-2008 05:02 PM
Jim -
I think you can make this work.
Just take the piece on the right of the throttle linkage plate (the one with the ball pointing to the right) - and flip it so the ball is facing the other way.
If however, that's the side that's solidly secured to the shaft - you'll have to cut and weld the linkage piece 180-degrees.
Good luck!
Glenn
jmshepard 05-31-2008 05:31 PM
thanks Glen! I'm on it.
Jim S.
sundevil64 09-07-2012 09:19 AM
I ran into the same problem on my car. FortunatelyI had this one that I suspect is a carrea piece in my drawer.
http://i475.photobucket.com/albums/r...D46339A485.jpg
This should work.
Flat6pac 09-07-2012 10:51 AM
In the first picture the lever to the right is backwards, the ball needs to be inside and the levers near parallel.
Bruce
