Brake Lights . . . Yet Again
Hi everyone,
I've got the same faulty, high-pressure-required, slow brake light switches that so many other 911 Carrera owners have discussed in other threads.
I am weighing my options for a cure.
Has anyone tried one of these:
from www.clparts.com?
Also, why wouldn't a door jam, interior light switch work as a mechanical brake light switch? Door jam switches see a lot of use/abuse, are pure Porsche, and not much money at all from our host.
Also, I have PM-ed Draco for more info. on his setup which, if I understand it, protects the switches from overload. Has anyone tried that setup? Has anyone tried that setup and found it reliable over an extended period of time?
As always, here's a "Thank you" to all of you who have helped all the lurkers like me out here trying to keep our cars safe.
Thank you,
EZMiles
1986 911 Carrera
1999 Exploder
1999 Honda Accord EX V6
1959 Farmall Cub
1941 Farmall Model B
Old 06-01-2008, 10:22 AM
That's a pretty elaborate looking brake light switch. Not sure there's enough room to install it in the pedal cluster area. Draco's solution seems to be valid; to reduce the current load through the MC pressure switches by using a relay.
A mechanical solution could attempt to duplicate the adjustable MC brake light switch on an early pedal cluster:
Sherwood
Old 06-01-2008, 11:24 AM
rnln's Avatar
maybe this will helps:
Brake Lights
Fat butt 911, 1987
Old 06-01-2008, 12:48 PM
Happiest when Tinkering
gsmith660's Avatar
I did something like this the momentary switch is robust it can use a dust cover and I sealed it up with double wall shrink tube, seems to work real good.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 06-01-2008, 01:02 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Hey EZMiles,
Several Members have ordered my Arc Suppressor. A customer of mine has used his for 5 months with no issues.
Scarceller posted his finding on Rennlist:
The issue is too much amperage on our BLS's
'85 Carrera Targa
PCA/POC
Old 06-01-2008, 05:10 PM
PSJoyce's Avatar
I installed Draco’s relay “Arc Suppressor” this afternoon. Fairly easy, just needed to temporarily move the A/C and heater hoses to get access. The system worked well in one afternoon’s worth of test driving. It is well assembled and thought out, and I think is a worthwhile addition to the car. It will take a while to see if it really does save the brake light switches, but I’m confident it will.
Paul
1985 911 Carrera
Moss Green Metallic
Steve Wong Chip, WEVO shifter & PSJ, Kuehl Air Conditioning
Old 06-01-2008, 06:41 PM
DRACO A5OG's Avatar
Hey Paul,
That's great! Please keep us posted.
Jim
'85 Carrera Targa
PCA/POC
Old 06-01-2008, 07:17 PM
