air filter
new at this and before I start, are there any tricks involved in replacing air filter in my 86 carrera??
Old 06-03-2008, 06:03 PM
Just make sure you disconnect the flux capacitor
86 911 Targa
Old 06-03-2008, 06:06 PM
msk1986911's Avatar
It can be a challenge to get your hand to the back side of the cover to unclip the clips at the top and bottom. Just make sure the clips on the cover are in the proper orientation when you reinstall the cover.
Old 06-03-2008, 06:46 PM
It helps to have a skinny arm, like a 10 year old skinny kid. Since I don't have any 10 year olds around I usually have to hose down my right arm with WD-40 so I can force my arm into the area necessary to get my hand on the clamps. I guess you could use soapy water but I had Wd-40 right there and ready to go.
Old 06-03-2008, 07:01 PM
My arms are sorta fat. I remove the oil filter (very little mess) and it gives me the necessary room to reach around and release the clips.
Old 06-03-2008, 07:31 PM
fun with air filter
thanks for your help, I think removing oilfilter makes good sense, thanks
Old 06-04-2008, 10:59 AM
3.2 CAB's Avatar
When changing the oil and oil filter is the best time to replace/check the air filter, otherwise it is a PITA, as others have said.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 06-04-2008, 11:33 AM
filters
Thanks again, I'm sure it'll go OK now. Still need to find that darn flux capacitor. I'm sharpening my hedge clippers and when I find it , it's gone. TKS
Old 06-04-2008, 12:20 PM
