Why not GHL?
They look NLA from GHL. The competion in that market is disappearing much the reason why we are making them as still a large demand |
Not sure what you mean by market is disappearing. I'm I the only one out there buying these? On pre-95 cars in IL once you test smog free you are no longer required to test. I installed a GHL bypass, O2 delete, SW re-map and it goes like...you know what.
If you reread what I said is that the market is disappearing so the big guys are leaving the seen and moving on. I know that I sell a bunch of 1 in1 out mufflers and almost everyone is asking for a premuffler. |
I would be interested to see if there was a real power difference between using the pre-muffler vs a CBP (I'm being brand ignostic now). I can't imagine it is much. From the posts I've seen in the past, there's a desire for a pre-muffler to avoid failing the visual test at the emission center which is not an issue here in IL. I'm also sure that a big part of the power difference I got came from re-mapping the chip. |
| All times are GMT -8. The time now is 11:48 PM. |
