-   -   911 decklid conversion to 964 wiring help ? (http://forums.pelicanparts.com/porsche-911-technical-forum/412915-911-decklid-conversion-964-wiring-help.html)
søren buresø 06-04-2008 03:01 AM
I have already the 964 deck lid fixed onto the car but the wiring is a mess - have all wiring and motor to open and close the lid but the wiring ends in a she plug.
Does anyone have a pictogram or some drawing's to make the connection easy. I am looking at having a switch to open and close this manually if possible. I have tried other thread but the links are too old.:p:p
4sd911 06-04-2008 07:18 AM
Do you have the one touch? http://autoloc.carshopinc.com/product_info.php/products_id/9238/WC1000 This is the best way to open and close the spoiler.
søren buresø 06-04-2008 11:09 AM
No but I will buy this if someone will tell how to connect the wiring to do it right the first time - thks for the thread SmileWavy
shahram 06-04-2008 11:55 AM
I had this saved long time ago, hope it helps:
http://forums.pelicanparts.com/uploa...1212609303.jpg
4sd911 06-04-2008 11:56 AM
Here. http://forums.pelicanparts.com/porsche-911-technical-forum/8410-improved-one-touch-wiring-964-tail-retro-fit.html
If I remember correctly the one touch needs to be hot all the time (12 volt wire not connected through the ignition), and the window switch (12 volt) to control the unit needs to go through the ignition.
jpnovak 06-04-2008 11:58 AM
Might I suggest the "search" button.
This will get you started. There are a few additional links inside the thread.
http://forums.pelicanparts.com/showthread.php?t=128348&highlight=964+wiring+deckl id
søren buresø 06-05-2008 12:50 PM
Thks Guys & Jamie
Info looks great I will try to fix this and let you all know the result - many thks for all the support on this great forum:cool::cool:
søren buresø 07-16-2008 09:11 AM
Originally Posted by søren buresø (Post 3985922)
Thks Guys & Jamie
Hi Guys
As promised is here the result of the decklid 964 conversion on my 27 year old 911Many thanks for all your help and the wiring diagram and autoloc guiding. Everything work the first time - GREAT :D:D:D
Short videoclip of the result below
http://www.youtube.com/watch?v=heCReRmo0Ak
RoninLB 07-16-2008 06:43 PM
just for archives
i'll be using a DPDT momentary cole-hersee switch instead of the autoloc.
