911 decklid conversion to 964 wiring help ?
I have already the 964 deck lid fixed onto the car but the wiring is a mess - have all wiring and motor to open and close the lid but the wiring ends in a she plug.
Does anyone have a pictogram or some drawing's to make the connection easy. I am looking at having a switch to open and close this manually if possible. I have tried other thread but the links are too old. ![]()
Do you have the one touch? http://autoloc.carshopinc.com/product_info.php/products_id/9238/WC1000 This is the best way to open and close the spoiler.
I had this saved long time ago, hope it helps:
Here. Improved "one-touch" wiring for 964 tail retro-fit
If I remember correctly the one touch needs to be hot all the time (12 volt wire not connected through the ignition), and the window switch (12 volt) to control the unit needs to go through the ignition. |
I would rather be driving
Might I suggest the "search" button.
This will get you started. There are a few additional links inside the thread. got my 964 lid...where's those instructions...
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Info looks great I will try to fix this and let you all know the result - many thks for all the support on this great forum ![]()
As promised is here the result of the decklid 964 conversion on my 27 year old 911Many thanks for all your help and the wiring diagram and autoloc guiding. Everything work the first time - GREAT ![]() ![]() ![]() Short videoclip of the result below http://www.youtube.com/watch?v=heCReRmo0Ak |
just for archives
i'll be using a DPDT momentary cole-hersee switch instead of the autoloc.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
