Air conditioning fan squeaky!!!
Hi,
My 1985 Carrera's A/C evaporator is making a squeaky noise audible from the vents. The unit is located in the compartment housing the steering gear shafts and looks like it's sealed by 2 or 3 clamps. Anyone can post a complete diagram or have detailed procedure for taking it out to oil the fan shaft that's squealing?
Tom
Old 09-29-2003, 10:24 AM
Replace it..............I replaced the evaporator motor in mine, and documented it pretty well, so if you're interested, let me know and I'll send you the document.........
Michael
'98 Boxster in Ocean Jade Metallic
Old 09-29-2003, 10:32 AM
It's probably not the fan shaft, but the fan rubbing against the housing. You can take it out by unbolting the two brackets, unclipping the three clamps, and unplugging the wires. It's relatively easy to do, but getting the clamps back on is a huge pain in the butt. You can get the motor new from Pelican for about $100 from what I remember.
Old 09-29-2003, 10:37 AM
TerryBPP's Avatar
When the bearings start to go the pressure from the smugglers box lid will make the fan rub. Try running the a/c with the smugglers door open. If the noise stops its the fan bearings.
Old 09-29-2003, 10:38 AM
Hi Seadweller,
Please email me the detailed instructions. My email is Tshih@jstar-research.com
Old 09-29-2003, 10:54 AM
Indeed, and oiling the system is a short-term fix......
Believe me, it's not a heinous job, but it's not something you want to do twice either.
Michael
Old 09-29-2003, 10:55 AM
Masraum,
I hope the Freon lines are not disturbed in the process you described, also wouldn't removing the 2 bolts and wires and clips enable one to remove the top plastic lid to see the motor/fan?
Old 09-29-2003, 11:05 AM
mackpipes
Guest
Posts: n/a
I just replaced my blower fan on my '85 for the same reason. Be very careful not to crimp the capilary tube that goes into the top of the box and into the evaporator. It looks like a silver wire but is actually a hollow tube. If you break the seal on the "wire" you'll wind up having to replace your temp switch which the tube is part of. It's not a hard job, just don't force anything apart.
Old 09-29-2003, 12:48 PM
The only thing holding the two case halves together is four (4) spring clips. The bolts you see from the top secure the fan/motor assembly into the top half of the case, and also secure the two case brackets.
Michael
Old 09-29-2003, 12:51 PM
By the way, I sent the document over, but it's a large file, so hopefully you'll get it. The A/C lines are out of the way, and do not interfere with the removal of the top of the case (along with the integrated motor/fan assembly).
Michael
Old 09-29-2003, 12:52 PM
GB83SC's Avatar
Michael,
Can I have a copy also?
gtburitica@cs.com
George
My Owners Gallery Page
1983 911SC - Built July 1983 #2547 out of a total 2559 shiped to the US. in 1983. Could be the last U.S. production SC still running.
1995 BMW 525I
2001 Highlander- kid mover
Old 09-29-2003, 01:37 PM
On its way!
Michael
Old 09-29-2003, 02:36 PM
GB83SC's Avatar
Kudos to Michael for a great technical article
When someone takes that much time in order to save the next guy the trouble, it says alot about who you are!
Great work.
George
1995 BMW 525I
Old 09-29-2003, 04:07 PM
Thanks George..........
Michael
Old 09-29-2003, 04:16 PM
George..I would realy appreciate a copy as well...another winter project!
lane911@bellsouth.net
Richard Lane
1978 911SC
1973 "Clean" RS clone
Old 09-29-2003, 07:29 PM
GB83SC's Avatar
You got mail.
George
1995 BMW 525I
Old 09-29-2003, 07:40 PM
for anyone who hasn't read or gotten the write up that is being mailed around, no, contrary to what the books say you don't have to remove the freon lines, and the bolts/brackets that I am refering to aren't the 3 or 4 bolts that go into the housing, on the back side (towards the passenger's compartment) and on the front there are two stamped brackets. The one on the back is "L" shaped and the one on the front is on a diagonal, those, the thin capillary tube, the clips, and the power to the fan are all that need to be removed to get the thing out. It's a relatively easy job, but takes a while because it is in a somewhat awkward position.
Old 09-29-2003, 08:56 PM
WHCJr72S's Avatar
Michael,
Can I have a copy also? I have had the same problem for years
My Email is CilkerWJr@aol.com
Thanks Bill Cilker, Jr.
72S
Old 09-29-2003, 09:48 PM
Lorenfb's Avatar
Try spraying a lubricate can with a tube into the bushing areas. I had
a similiar problem and fixed it by lubing the fan bushings.
Good Luck
Loren
'88 3.2
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 09-29-2003, 10:27 PM
On its way Bill...........
Michael
Old 09-30-2003, 05:01 AM
