NGK in a 911... say it isn't so... in a 912, I'd be okay...
Yeah, I'd pull it out and look at it. As Bill said, maybe somone else cross threaded it at some point, but I promise you that you didn't with your fingertips. |
I know that Hugh is being cautious and trying to save you from a major screw up, but as another opinion - I cross threaded a plug a couple of years ago and had good luck ( and maybe that's all it was) carefully chasing the threads and reinserting. If you were installing by hand I'll bet they aren't buggered too badly.
Well I ordered the Back-Tap tool and it should arrive this week. I will use it Saturday and post an update.
When using a tool as described in Grady's post, apply plenty of grease to the tools threads (cutting edges). This will catch any small bits of metal that may be removed with the tool. I just ordered one from my local auto parts place. They said they will match the $45 Amazon price, no shipping, 3.8% sales tax, should have it next week. “KD Back-Tap 14mm Internal Spark Plug Rethread Tool. Patented design allows for chasing spark plug threads from inside the cylinder head and working outward. This tool uses the better threads at the base of the spark plug port and greatly reduces the chance of debris falling into the cylinder. Works on 14mm spark plug threads. Length of 6" allows for deep well plugs. Tool can be used with 1/2" socket or wrench. Availability: In stock Usually ships within 24 hours. Ships via UPS.” They say it is 6" long. Next week I’ll take some pictures using it on a disassembled head and try it on a complete engine. One issue with a 911 is that it make the turn and fit down the sparkplug opening and clear the chassis without removing the intake valve cover. This looks like a tool that belongs in everyone’s tool box. I’m going to see if it is suitable for regular sparkplug thread maintenance. This has always been a difficult issue. Perhaps it is somewhat solved. Best, Grady |
Problem solved--you won't believe it!
Ok here is the update I promised. I couldn't work on the car Saturday as I was in West Virginia most of the day. I got the Back-Tap tool and a mirror on a telescoping stick. I started working this morning.
I removed the valve cover and used the mirror to peer into the well. Boy was I surprised to see this... http://forums.pelicanparts.com/uploa...1213580749.jpg http://forums.pelicanparts.com/uploa...1213580773.jpg http://forums.pelicanparts.com/uploa...1213580797.jpg http://forums.pelicanparts.com/uploa...1213580822.jpg http://forums.pelicanparts.com/uploa...1213580844.jpg What are those white fluffy things? Why they are Bounty paper towels (the quicker picker upper). http://forums.pelicanparts.com/uploa...1213580916.jpg So I used my handy flexible claw to remove all traces of the paper. At this point I am elated--all this heartache caused by paper messing with the threads. So I eagerly grab the plug, insert it in the plug socket, then start to turn and the same things happens again--two turns and then resistance. At this point I know I will have to use the Back-Tap. http://forums.pelicanparts.com/uploa...1213580630.jpg http://forums.pelicanparts.com/uploa...1213580668.jpg I lubricated the threads with grease and inserted into the chamber. The Back-Tap has a knob on top you turn clockwise to pull the draw bar and adjust the tapered thread to full 14mm. Now this is easier said then done as the tool is just too short. I say it needs another two inches to make it a perfect tool. I could just BARELY turn the draw bar knob with the tips of my fingers. Compounding the problem is the the body of the tool wants to turn with the knob. So I pushed down on the tool so it rested against the piston then I turned. The friction from the piston held the draw bar and let the knob turn. I then grabbed the tool and lightly tried to pull it out. The draw bar had not expanded enough so the threaded tip slipped easily past the threads the tool came out. I put it back in and turned the knob some more. Again I tried to remove the tool and felt the thread finally engage. You have to be careful when turn trying to back tap as it's easy to turn the draw bar knob, thus releasing the draw bar and the tool slips out. The instructions say you should use it 2-3 times expanding the diameter each time. I did it a total of four times. I did feel slight resistance but nothing I would classify as "torn up threads". I also did not see any metal particles in the grease. Regardless I did clean the tool and reapply new grease each time. I grabbed the plug again and said, "here goes nothing". Lo and behold the plug went in like butter. I started the car and she ran just fine. So the tool is worth every penny of it's $50. The only con I have is that it just needs to be longer--about two inches. Thank you every one here for your support. |
Congrats Howard, glad it worked out, and I knew the threads couldn't be too bad.
Sounds to me like you had miniscule amounts of debris or corrosion. You can tell just by looking at the plug that it's not cross-threaded. Personally, i would've just twisted a bit harder inserting it the first time. |
congrats and well done, you should be proud of yourself. a lot of people wouldn't have stuck it out. Not sure what those white things were, I thought maybe electrode at first.
Nice job, I am glad it worked out!!
Paper towel gave it enough of a push to start the plug down the wrong path? Looks like an interesting tool. |
Great post!
hell'ova wild adventure tale
Ok, fess up, where did the paper towel come from?
Neat tool...bookmarking this thread.
How the $)(@# did you get paper towels down in there? :eek: |
| All times are GMT -8. The time now is 12:14 AM. |
