911 carrara misfiring
My 1986 carrara has been misfiring (like it has has some water in the fuel or was running out of gas. At first I though I had purchased some bad gas. When I had used one half to the tank I filled up. It ran rather well until I was almost out of gas and It began to skip quite a bit.
I filled up again and it skipped a couple of more times when I left the station. I was close to home and did not run it any further.
I am wondering if that is a sign that I need to replace the gas filter of is the electric pump going bad. What else could be causing the skipping?
Thanks for your help
Regards,
Marc Gifford
Old 06-17-2008, 01:20 PM
did you wash the car recently? loosen the spark plug wire holders, and turn the 2 screws that hold down the distributor cap. Turn the cap over, and look for water. If you see water, then dry the cap, reinstall.
Also, try running the car at night in the pitch darkness. If you see a lightshow, time to change spark plug wires.
Old 06-17-2008, 01:32 PM
burgermeister's Avatar
Could be the fuel pump too ...
Edit: Oh wait, you already mentioned that.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 06-17-2008, 02:54 PM
How old are your ignition cables?
Old 06-17-2008, 07:45 PM
BReyes's Avatar
Could be anything. I'm thinking that if it has not gotten wet (eg, rain), and has been well serviced, maybe a little gremlin such as a loose connection. Definitely needs a little service.
Guys would a bad/dirty MAF do this?
Bernard
Old 06-17-2008, 09:50 PM
Possibly. However, ignition would seem to be a more likely culprit.
Old 06-18-2008, 08:52 AM
gtc gtc is offline
abides.
gtc's Avatar
Check the spring loaded carbon electrode in the center of your distributor cap. I had one break once, and it gave me very similar symptoms.
Graham
1984 Carrera Targa
Old 06-18-2008, 11:09 AM
Make Bruins Great Again
Por_sha911's Avatar
How long has it been since you replaced the DME Relay?
Joe
Old 06-18-2008, 05:38 PM
A fuel injector may not be electronically functioning. With engine running, disconnect injector harness from injector one at a time. Engine speed should fall each time until you find the one that;s bad where there will be no change in RPM.
1987 Carrera 3.2
Old 06-18-2008, 07:45 PM
