				What is this (firewall)
			I'm in the process of removing all glue residues from my firewall, before replacing the insulation. I found a rubber hose that look like some kind of drain and a pair of threaded holes that will be covered by the insulation. Anyone know what the hose and the holes are used for?
	1977 911 2.7 Stock restoration in progress  |
			 Max Sluiter
			Looks like a drain line for the rain gutters and the rear window surround.
			Not sure, though.
	1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance  |
			is it  a rubber insulating tube for the rear window grid?, what is the view from the topside?
			LM
	83 SC  |
			Only a guess.  The tube may actually be the "conduit" for the wires to the rear window defogger rather than a drain.  The threaded holes may used for something that is screwed in from the interior rather than the underside, as they have glue on them and were previously covered.
	L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip  |
			 Immature Member
			Definitely a wire shroud.  Mine has two brown wires running in it which enter into the fenderwall behind the fuel filter.
	1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!"  |
			It is the wire cover for the wirs for the rear window defrost grid.
			the sunroof drains come out on each side benneth the window but above the deck lid "lip". LM
	83 SC  |
			Ok, it doesn't show in the picture, but my next question might be "Where are my defrost wires?". As far as I remember there are no wires exiting the hose. Must take a look next time I'm in the garage.
			possibly (hopefully) still attached to the rear glass or tucked into the rear glass seal.
					LM
	83 SC  |
