Arias Pistons?
I was hearing a noise that I didn't like while running one of my 2.0L motors, or atleast I thought it was a 2L. When I tore the engine down I found these muthas. The inside reads "Arias" and "535-SS". Anyone ever use this brand and happen to know what the compression ratio is?
Old 04-13-2008, 02:46 PM
911quest's Avatar
I have the same set as those probably 81mm they are very beastly pistons @ 11 to1 compression I talked to EBS and they said they can get me rings for them...
Tony Proasi
1969S
1957 VW Pickup
Old 04-13-2008, 02:55 PM
They used to be very popular for the air-cooled crowd. Competition Engineering carried them when Ray Litz was around. They do look beefy don't they? I believe Arias is still around in Gardena, CA.
Sherwood
Old 04-13-2008, 03:45 PM
Yes Arias made a run of pistons for Ray at CE. I had a rare set for my 914-4 at one time. Arias is big with the drag race crowd.
Old 04-13-2008, 03:48 PM
I will check tomorrow, but I think these were 87 or 88mm.
Old 04-13-2008, 04:41 PM
MBEngineering's Avatar
HI John
have taken these out of a "2.0"Lt engine (in-port from USA) and thay look like yours, these are 86mm and NLA, Arias would make some more for me at a price as thay have no drawings for them now.
the engine came apart for a noise when cold, and this was the prob'!!
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 04-14-2008, 04:02 AM
Yeah Mike. That's the same one. I must have read the 3 as a 5 for the first digit in the part number. I have been working off my photos as the pistons are back at the shop.
Did your motor have the stock heads bored out to accept the pistons, like mine? How stupid is that!? All that compression and small intake and exhaust ports.
I had an extra good motor that I robbed correct heads, pistons, and cylinders off of to fix my problem. One of the pistons was hitting the head. I assume from over heating. I think my pistons are still good. They look it. If you could still get a set of rings, maybe you could use mine as a replacement? That is, if you need them. Let me know.
Old 04-14-2008, 04:26 AM
These do infact measure 86mm. Thanks Mike.
I have cleaned em up and putting them in a box for storage. We will see if I ever have an occation to build a motor w/ them. Thanks all.
Old 04-14-2008, 10:33 AM
Turbo 13b guy
JayG's Avatar
I ran Nick Arias pistons in a 400 hp Mitsubishi forever. Nice quality.
1975 911S Targa(333 hp/276 tq)
Old 04-14-2008, 11:35 AM
HI John
The engine I have hear looks like the one you have, with the heads modified to fit the cylinders and the cases bored also, the heads are STD "L" engine spec', the engine is being re-built and waiting for some fresh cylinders at the moment, it is up to this stage;
with one of Supertec twin plug dist.
The pistons have been changed for some JE ones, from Supertec.
regards mike
Regards mike
Old 04-15-2008, 01:17 AM
Looks very nice, Mike.
Old 04-15-2008, 04:31 AM
HI John
Just to let you know I have the engine back in the car now and heading for the rolling road for a set up, it finished off looking like this,
will let you know the out come of the rolling road and then if you decide to rebuild your engine I will PM you the speck' of this if you would like it.
regards mike
Regards mike
Old 05-21-2008, 01:57 PM
And what a peach of an engine you built Mike - very rewarding to drive
Hope you don't mind me chiming in!
Regards
Ian
Old 06-09-2008, 08:59 AM
