LinkBack | Thread Tools | Rate Thread |
Tony
Why did Porsche not want my electric oil cooler fan to come on until 244 deg?
I was sitting in traffic on Friday (summer has arrived in VA) with the a/c on and the oil temp got real close to the second white hash mark (around 248 deg). I never heard the fan come on. So I came back and looked up what temp the fan is supposed to come on - at found out that its 244 deg F. Even though the red part of the gauge doesn't start until 302 deg F, people here say you should get over 250.
My question is why would the factory set the thermoswitch temp so hi? They must have had a reason. I have read about swapping the thermoswitch for a BMW part that opens at 230. Others have wired a manual switch. I am thinking about the former. Thing is that Porsche engineers usually have good reasons for what they do - any ides?
Tony 22 GT4 04 E46 M3 87 Carrera (sold - craving aircooled again) 12 991 Carrera (sold) |
I think it is just a simple wire slice to have it run all the time with the engine on. That is one option to look at.
Tony,
Porsche allowed these engines to run that hot for emissions compliance. They are not as concerned about engine longevity and durability.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
I have heard that the fan is not a real long lasting unit. If you run it all the time it will fail soon. My 85 Carrera did not come with a fan. I added a fan and just put in a toggle switch. If the temp is over 200, on goes the fan. I figure it is a human interface temperature switch. I never need it in the winter months.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Tony
I was thinking of installing the bmw 99 deg C (210 F) thermoswitch - I like the idea of an automatic switch rather than a manual just in case my wife is driving the car.
That still seems so hot - emissions or not.
I've heard about that lower temp switch. But, what BMW switch is that specifically?
thx todd 89 targa |
Most folks install both. You can switch on the fan anytime you want...but if you forget, it will come on when the temp exceeds 210F.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
I understood the fan only delivers adequate cooling when the oilcooler is really hot.
carrera coupe 85 |
I installed the fan kit from Elephant Racing. It comes with an adjustable thermostat. IIRC The range is something like about 170 to 280 F.
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
I would think you should see at least 212- degrees to get any moisture out of the engine. You can run too cool. There's an optimum temperature. To cold is as bad as too hot.
You engine makes it's best power running a little on the hot side. In fact most engine show peak horsepower just before they blow up - but that's another story. Richard |
Tony
Richard,
That goes back to th original question - maybe its no so bad to run around at 250 degrees if the factory didn't have the fan come on until 244 and the red line is placed at 300. I know I get nervous when the needle gets there, but maybe I shouldn't. I have to check the owner's manual to see if it says anything...
