whackit's Avatar
Remove & Replace Bilstein strut top seals?
I need to remove the top seals prior to getting my strut bodies powder coated. Anyone know how these come out? I don't want to mess them up since I'm having a hard time with replacements (Bilstein says they won't just send me the part i need to send them the strut).
1971 911E 2.7RS interpretation -- Signal Orange baby!
Old 06-11-2008, 06:04 PM
Sorry I can't help but I'm Interested as well.
LM
83 SC
Old 06-11-2008, 07:43 PM
joefrantz's Avatar
Mine were just a very light press fit. You should be able to pop it out with a screw driver and slide it back in with finger pressure.
Joe
Joe Frantz
73 911 T
Old 06-11-2008, 10:32 PM
joefrantz's Avatar
I just noticed that mine had a different (smaller) cap on the top of the strut. Possibly an older design. I did have to remove the cap by taping it off with a drift before removing the seal. I haven't done one with the larger cap like yours.
Joe
Joe Frantz
73 911 T
Old 06-11-2008, 10:37 PM
whackit's Avatar
I got someone at Bilstein whop tracked the part down for me. The seal is part # E4-B36-800A and they were $13 ea. I'm waiting to see what they look like but I'm assuming they are press seals similar to a crankshaft seal. I'll post pics when I get it all together.
Old 06-13-2008, 05:06 PM
Don't forget to order the lower split pins as I can't find anyone who sells them.
LM
83 SC
Old 06-13-2008, 05:52 PM
abit off center
cgarr's Avatar
When I rebuild them I use regular 46mm OD wiper seal you can get from any bearing shop for about a buck each, its not an uncommon size.
______________________
Craig
G2Performance
Old 06-13-2008, 06:13 PM
whackit's Avatar
Okay, so removing the seals couldn't be simpler. Just get a small drift and place it on the side of the seal. The outer portion is metal like on an engine seal. Position the drift (or screwdriver, whatever) on the outside edge of the seal. Give a few soft taps making sure that the tool doesn't scratch the inside of the aluminum bore. The seal should just pop inside the strut at which point you can rotate it 90 degrees and pull it out. My seals looked perfect after this and I would re use them. To reinstall simply tap the new one in until flush.
Old 06-14-2008, 04:03 PM
82 911 SC - Ancora Imparo
I am also getting my struts blasted and powder coated. So I pulled out the wiper seals and ordered the ones mentioned above from Billstein. I just received the new ones today and they do seem a little bit different from the ones I removed. See the pictures attached below. The OD appears to be correct but the bottom side of the seals is not solid, almost like it is supposed to be pressed on the something.
Can anyone confirm this is the correct seal?
Ethan
1982 911 SC - Wine Red Metallic Coupe
Old 01-25-2022, 06:00 PM
If you order them from Bilstein, they are priced reasonably, but the shipping over the pond is wsy too much. $12 each and $84 shipping. I bought from summitracing.com for $20 each and $12 shipping.
Question, what kind of grease was used upon original assembly? It is off white and doesn’t seem to dissolve in my solvent tank. I’m using mineral spirits.
Old 06-10-2024, 07:43 AM
PCA Member since 1988
If it doesn't dissolve in mineral spirits, it's almost certainly a silicone based grease. Probably the same as what's used on brake parts.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-10-2024, 02:07 PM
I was thinking like something from the 1800’s like Bear Grease.
The color and consistency are unlike any silicone grease I’ve seen. I think I may ask Bilstein the question. If they have a decent Customer service.
Old 06-10-2024, 02:16 PM
Pete, as I recall it was more like a soap. I’ll be using Red line grease.
Old 06-10-2024, 07:40 PM
