-   -   Checking Mixture - LM1 at Idle on 82SC (http://forums.pelicanparts.com/porsche-911-technical-forum/414806-checking-mixture-lm1-idle-82sc.html)
mca 06-15-2008 08:02 AM
I borrowed a buddy's LM1 so that I could check my mixture.
I am prepping this CIS to be placed on a rebuilt engine and I want the mixture to be as accurate as possible.
OK, at idle with a warm engine should the Lambda number on the LM1 be between 0.800 and 0.900? I believe that equates to 14.1 - 13.2 for the air/fuel ratio. Is that correct?
jess p 06-15-2008 11:19 AM
As you know Lambda 1 is 14.7. At idle this is where I try to be and then check
lambda at 3000 rpm. I prefer to be just slightly rich up to wot. Go to www.innovatemotorsports.com
There is a section at this site on 911 cis 3.0l
mca 06-15-2008 03:20 PM
Ok ... thanks for info. This applies with 02 sensor connected as well as with disconnected?
Can't seem to find anything about 911s on the site. Searched LM1 forum too.
jess p 06-16-2008 11:28 AM
Go to general tuning forum, then 911cis
