Danny_Ocean's Avatar
This product contains 10% Ethanol...?
For the first time ever, we now have gasoline mixed with 10% ethanol here in FLA. Will this affect the fuel systems of our stock 911's? How about E-85?
Old 06-17-2008, 02:09 PM
Friend of Warren
E10 yes, E85 no.
Kurt V
Old 06-17-2008, 02:25 PM
Designer King
Paulporsche's Avatar
If you do a search, you will find lots of discussion on this. 10% generally seems OK. More than that will affect different types of fuel systems differently. CIS cars seem particularly vulnerable to the effects of alcohol.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 06-17-2008, 02:26 PM
Originally Posted by Kurt V View Post
E10 yes, E85 no.
Meaning E10 = OK to use and E85 not OK to use?
Old 06-17-2008, 03:01 PM
Monkey Butt Forespin
84_Carrera's Avatar
I think what Kurt means is, "E10 is a Yes / Go; E85 is a no / No-go".
Pretty much the whole US has E10 now (10% Ethanol). Run down an MTBE-added fuel load to the bare minimum, fill the tank w/ E10, add a bottle of dry gas occasionally, and change the fuel filter a couple of times during the changeover. E10 will attach the crud that's been settling on the tank walls & stir that up into your fuel, so watch the filter. I did 2 filter changes on my 3.2L after the changeover, now doing them annually.
I noticed about a 3% loss in power after going to E10, and fuel mileage went down slightly as well.
As mentioned, lots of good info on here & elsewhere on the web.
Fred Hurder Jr
For Tech Questions:
'84 911 Carrera Cabriolet (US)
Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler
22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks
ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars
Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans
Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Old 06-17-2008, 03:04 PM
Wavey's Avatar
We've had 10% ethanol for at least a decade (pretty sure longer) here in Illinois, and I've never had a problem with it in anything - '88 Carrera included for the last 6 years. Not to worry.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 06-17-2008, 03:11 PM
scottcip1562's Avatar
You can still get non e10 at Cosco. I agree the filter needs to be changed more. I have done this twice since the e-10 mess. Each time the filter dumped out cleaner gas. Anyone remember the Gasahol days from the 70's. My dad's fuel filter in his 72 F150 would plug up 4 times a year.
79SC, Wevo Shifter, SSI, Koni's, MK Muffler
85 944 Stock
Past Porsche's
87 944
87 928S4, I was young and dumb
99 Boxster
70 911T
Old 06-17-2008, 06:11 PM
That's funny, as Costco is where I regularly purchase my gas and they just started offering E10 only. Other stations around here do not have it.
Old 06-17-2008, 08:44 PM
