Hi
Coil Question
I have a 84 Carrera with a stock 3.2
If I suspect an intermittent problem with my coil can I swap coils with a Ford coil? Let me know. thanks. |
Air Medal or two
I put on a high perf coil on mine several yrs ago not a ford...but I would guess a 12 volt coil is a 12 volt.
the only issue I can guess are some (not Ford )run a ballast resistor.. which if needed would just make the coil over heat and melt dwn So I think you are safe
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Air Medal or two
What kind of intermittent problem? |
