-   -   PERTRONIX_ No start problems and I have searched and searched (http://forums.pelicanparts.com/porsche-911-technical-forum/414869-pertronix_-no-start-problems-i-have-searched-searched.html)
davis911s 06-15-2008 02:09 PM
Well I thought today I would take the kids for a nice Fathers Day drive. (My kids have yet to drive in my car :( )
I had a few minutes to kill so i thought I would install the pretronix I got with my last order.
I started the car up, let it idle for a few minutes. (i did this just to be sure) So I installed the pertronix as per instructions (and browsing the forum)
When I go to start it, it will not start
I am frustrated I had the black to the old points lead and the red to 12V
This is where it gets worst! I curse the pertronix and re-install the points. Now it still won't start. I am pissed. My fathers day treat is passing me by :mad:
I changed CDI boxes just to be sure (I have 2 spare that worked a few years ago).
So where can I start looking?
I disconnected the wiring
With the key on:
- I have 12V at the coil but not at the points lead ( I was sure I had 12V there before ?
I checked "continuity?" on the coil, my multimeter beeps when I touch the two sides.
Only thing I can think of is that I may have put the distributor back in wrong? Or off a few teeth. I was extremely careful when I pulled it to ensure I didn't move the cogs and that it went back exactly where I took it out from.
With ignition on should I have 12V at the points lead?
PLEASE HELP ME, I am losing daylight
Shawn
davis911s 06-15-2008 02:37 PM
Can I have the harness hooked up backwards at the CDI box? It will fit either way.
And this changes where the voltage goes (switch between the points pick-up and the coil)
Also one of my "spare" CDI boxes is a Bosch silver and it is whining, I know this is not the end all be all but thought I would add everything
THIS SUCKS
davis911s 06-15-2008 04:02 PM
UPDATE it is FIXED
After searching more I found this link that helped me determine the proper connection.
Originally Posted by HarryD (Post 3448932)
You better check your wiring diagram. Per Permatune (http://www.perma-tune.com/T-ignition-Porsche-911.html):
A = + or 15, coil hot primary terminal ( - or 1, coil ground primary terminal is connected to the engine ground).
B = Power from ignition switch.
C = Distributor breaker points.
D = Ground
BENCH CHECK OF THE IGNITION BOX (Perma-Tune only)
PIN A TO D = 3,300 Ohms +/- 100 is normal . Zero Ohm or lower than normal resistance indicates defective ignition coil damage to the box.
PIN B TO C = 100 Ohms, +/- 1 is normal. Open circuit or higher than normal resistance indicates ground loop or over voltage damage to the box.
PIN D TO MOUNTING FLANGE = Zero Ohms is normal. More than 0.2 Ohms indicates ground loop or battery terminal reversal damage to the box.
Hooked it all back up ---WITH POINTS and it runs SmileWavy
After supper I am taking my kids for a spin (one at a time)
I checked and I DO NOT have 12V at the coil with the key on. Only to the points.
I also double checked my two spare CDI boxes and they are working :)
Shawn
tmctguer 06-15-2008 08:11 PM
for what its worth, i recently posted my successful Pertronix installation process in a '73 911E here:
http://forums.pelicanparts.com/porsche-911-technical-forum/412669-pertronix-installation-73-911e-complete-photos.html?highlight=pertronix
it is probably something very simple. for example, did you put the rPertronix ed/black wires into the correct red/black at the CDI unit? are your connectors crimped properly? did you take care to put the engine to TDC and double check your rotor position after re-installing the distributor?
jasonmx5 06-16-2008 07:34 AM
Did the same thing, had the same frustration as you. Follow this diagram below rather than the instructions in the Pertronix box and you should be all set. Also included a link to my thread when I ran into the same problem.
http://forums.pelicanparts.com/uploa...1213626028.jpg
http://forums.pelicanparts.com/porsche-911-technical-forum/405095-i-think-i-broke-post-ignitor-install.html?highlight=pertronix
If I remember correctly - hook up the red wire to a switched power source - I think #2 of the three fuses in the engine compartment should work (search to verify). You'll probably have to extend the wire to reach. Hook up the black wire to the tach lead and you should be all set. (again search to verify as it's been a few months since I did this and don't want to give you bad info.)
