SSI exhaust fitment questions
Hi,
I came across a complete exhaust systems that the owner want to sell because he want less noise. He just run it for less then 3000 mi.
It's a pair of SSI heat exchanger SSI484940 and SSI434182 and a stainless muffler, single outlet, but bigger, 911.111.025. I plan to built a mildly modified 3.0, but I don't have the motor yet.
What are the range of motor can I use this system ? and induction system restrictions ? What will be a good price to pay ?
Thanks !!!
65 coupe, Dolphin gray #1506
70S coupe, Blood orange #1436
R Gruppe #647 ; S Registry #1666
Old 06-16-2008, 08:19 PM
Bill Verburg's Avatar
SSI are a very good choice up thru 3 maybe 3.2 L, the main issue is thick vs thin flange.
early 911 thru ~'81 used short exhaust studs and thin flanged exhaust, after that they used longer stud and thick flange exhaust. The studs can be changed to thecorrect length(i've doen that several times) it's just another PIA job
Of course the correct oil lines are needed as well, that also depends on the specific year.
SSI can be used w/ most any cam or induction variation w/o restraint. They do fall into the small side on a 3.2 w/ lumpy cams & raised rev limit.
Bill Verburg
Old 06-17-2008, 03:56 AM
Thanks ! Any clue on the market price ??
Old 06-17-2008, 05:48 PM
John-1977911s's Avatar
Correction to Bill's comment -- early 911 thru ~'81 used short exhaust studs and thin flanged exhaust, after that they used longer stud and thick flange exhaust. The studs can be changed to thecorrect length(i've doen that several times) it's just another PIA job
My '77 uses the thick flange SSI's.
John D.
1977 911s Targa
Old 06-18-2008, 12:16 PM
Friend of Warren
New that set up would run you around $1500.
Kurt V
Old 06-18-2008, 12:19 PM
