I am in the market for a new (used) 915 for my '71E. I was wondering what years of 915 would best suit my car? I got an electronic speedo rebuilt to look like a '71, so I am set up for that, but my biggest concern is the gear ratios. The car currently has the 2.2E engine in it and a dead mag 915 (numbers are to scratched to see what they are). I found a '77sc 915, would this work well?
Thanks! Brent
'71 911E Targa Last edited by 911Etarga; 06-19-2008 at 10:30 AM.. Reason: 77sc |
Check for a plugged vent on top of transmission.
AutoBahned
the '77 escapes the bad designs of the earliest 915s.
it is actually stronger in some ways than the later Al transmissions & is lighter too all Mg cased items need serious protection from corrosion There is a thread with some tables in it on the "best transmission" BUT the '75 & on tranny's have a 7:31 R&P (aka CWP), and "the 7:31 R&P will lower ALL the gears." see: http://forums.pelicanparts.com/porsche-911-technical-forum/400449-915-trans-gearsets-ring-pinion-change-post3852593.html#post3852593 |
Thanks for the feed back!!
I think I want the 7:31 for my 2.2. A little more power of the line would help. Just for reference, should a 2.2E with carbs be able to out run a Civic? Mine wouldn't right now...... And in 5th there is nothing, I can't even get up a small hill without shifting into 4th (the only gear that seems to have power) The engine was just rebuilt, so I am trying new jets (55) to see if that does anything.
'71 911E Targa |
